Old May 23, 2016 | 09:03 AM
  #571
VenomGT9's Avatar
VenomGT9
you'd probably be able to bump up to 255 for a little more tire
Old May 23, 2016 | 09:28 AM
  #572
JBurch175's Avatar
JBurch175
Thanks for the pic! This is going on my wife's car and I want it to be a solid setup, so thanks for replying. I read somewhere on here that with a 9.5 you should run a 255 tire, do you feel that would make this a better setup or no?
Old May 23, 2016 | 09:31 AM
  #573
JBurch175's Avatar
JBurch175
ha! Thanks Venom, I believe it was you that posted that. So, no rubbing with the 255?
Old May 23, 2016 | 10:45 AM
  #574
ChinkyChoy's Avatar
ChinkyChoy
Originally Posted by JBurch175
Looking to verify my setup before I make a purchase. I'm interested in Stance SC-6ix wheels in 19x9.5 square setup with 245/40/19 offset +35. Im also purchasing KSport coils to complete the setup and get the proper drop. Any and all suggestions would be greatly appreciated.
exact same set up I had on the first page of this thread.
it will work fine
Old May 23, 2016 | 10:49 AM
  #575
VenomGT9's Avatar
VenomGT9
Are you dead set on those wheels...?
Might I recommend something similar and of better quality
Old May 23, 2016 | 10:59 AM
  #576
the93owner's Avatar
the93owner
245 or 255 will work just fine on a 9.5. 255 is a little better fit width wise but 245 won't give you any problems either, and a little more room at the fender.
Old May 23, 2016 | 11:15 AM
  #577
JBurch175's Avatar
JBurch175
I am set on that style of wheel, but not particularly Stance....So any/all suggestions are more than welcome. I'm trying to put a fairly decent wheel on the car but nothing Ill be upset with my wife over if she hits something accidentally Id rather buy a new wheel than argue for sure! I like those Enkeis by the way and they seem to be comparable in price! You know of anyone running them so I can see a pic?
Old May 23, 2016 | 11:23 AM
  #578
VenomGT9's Avatar
VenomGT9
Enkei is a great brand with many options, also they go through JWL which (most) cast companies do not.
Not sure on specs...work is blocking my access to the Japanese sites lolll
Old May 27, 2016 | 09:02 AM
  #579
Guess it's my turn to join~
Going from staggered 20s to lightweight 18s.
Wheels~Wedsport SA10R 18x9.5 +38
Tires~Kumho Ecsta LE Sport Max Performance Summers, these easily clear Akebonos too!
Old May 29, 2016 | 12:54 AM
  #580
ai3j50's Avatar
ai3j50
Originally Posted by ai3j50
So I've decided on the Niche Targa wheels in 19x9.5 all around. Online I only see them in +35 offset but my local shop is saying they can get them in +25 and +40. I plan on putting sport brakes on the car and testing the +35 wheels with the template, the calipers will be about 2mm from touching the wheel. The shop is telling me that +25 wheels well clear the calipers with space but much stick out further than the fender. They don't have +25 Targas in stock so they would have to special order them for me....
Not sure what to do here. Will 19x9.5 +25 stick out? Should I get the +35 and use spacers if I need them?
Also blnewt recommended 265/35/19 tires but those seem to be more rare/expensive. Can I run another similar size like 255/35/19 or 275/40/19?
Hey guys I finally pulled the trigger 2 months ago and purchased the Niche Targas. I went with 19-9.5 +35 all around wrapped in 255 /35 R19 Cooper RS3 Summers. All recommendations from this thread. When I put the wheels on I also did the akebono upgrade, I have an X. I have to put a 3MM spacer on the front as the rim was just hitting the caliper. Just wanted to share with you guys since you help me narrow down my sizing.
Old May 29, 2016 | 11:27 AM
  #581
Nice looking wheel choice for your coupe, looking good
Interesting that the template showed 2mm clearance but you still needed a 3mm spacer to clear the front calipers. There seems to be a bit of wiggle room w/ those templates but not in your case obviously
Looks like you've got room for wider tires if you want to get further to the fender in the future, from the pics it looks like a 275/35 would fit just inside.
Look forward to how you like those Cooper RS3s, they aren't common here but I researched them when I got my Kumho Ecsta LEs (which aren't common here either, lol), and they get solid reviews. Keep us posted, nice job on the BBK too, color goes well
Old May 29, 2016 | 03:03 PM
  #582
BrianG314's Avatar
BrianG314
2011 G37xS with Niche Verona 20 x 10 +40 wheels all around with 255/35/20 Kuhmo Ecsta 4X II tires
Old May 30, 2016 | 05:25 PM
  #583
the93owner's Avatar
the93owner
19x9.5 +33 on 245/40/19. Perfect fit all around!
View this post on Instagram
Old May 31, 2016 | 08:00 AM
  #584
jfisher's Avatar
jfisher
https://www.instagram.com/p/BGCSizvR76J
Looks good! Any shots from above the fenders looking down onto the wheels?
Old May 31, 2016 | 11:44 AM
  #585
the93owner's Avatar
the93owner
Thanks! I'll grab some shots later this afternoon. If you're afraid about rubbing, I don't have any problems with that.
