Old Mar 16, 2016 | 09:27 PM
  #421
007pipeline's Avatar
007pipeline
this is all great info for a new G driver...!! i been a nissan man forever and finally upgraded...
keep the info coming!!
Old Mar 16, 2016 | 11:59 PM
  #422
Welcome to the site, any plans for your new G?
Old Mar 17, 2016 | 08:18 PM
  #423
007pipeline
Typical stuff. Rims/lowered/exhuast/intake and intake manifold.. etc...
I have owned a 99 maxima/05 ser/ gtp.. I have modded a few times before..
Old Mar 17, 2016 | 09:26 PM
  #424
MattCica's Avatar
MattCica
With spring coming I'm looking to get a new setup for my 2010 x coupe...but I can't make any sense of the wheel calculator. I saw somewhere in my searches that a square setup with 19x9.5 +35 rims and 265/35/19 tires would work with the awd system. Can anyone confirm this or suggest a safe setup that won't cause any issue. I'm not dropped but may want to in the future and have standard brakes.
Also, anyone know the rim specs on the 18" journey coupe rims? That might help me when using the calculator because I was finding different answers when searching..
Cheers
Old Mar 17, 2016 | 10:00 PM
  #425
Cheers
You'll want to see fellow staffer Lt8ches coupe, he's running 9.5 +30 on 265s so your +35 will have about 5mm more room at the fender, should be a great fit And you will want to drop your G a bit, he's dropped on Eibachs His are 18s but will still be the same fit at the fender since the tires are the same height, and his is AWD too.
https://www.myg37.com/forums/brakes-...ml#post3815735
OEM 18s are 18x8 +43
Old Mar 17, 2016 | 10:38 PM
  #426
the93owner's Avatar
the93owner
New setup! 19x9.5 +33 with 245/40/19 on all corners. Absolutely no rubbing!
Old Mar 18, 2016 | 12:16 AM
  #427
You mean new "sexy-as-hell" setup Mr. 93!
Old Mar 18, 2016 | 10:38 AM
  #428
the93owner's Avatar
the93owner
Thanks! Fitment is perfect. I do have a little more wiggle room if I wanted to add a 5mm spacer or so, but I don't want to push the envelope. I enjoy not rubbing
Old Mar 18, 2016 | 07:29 PM
  #429
evil-G-nius's Avatar
evil-G-nius
Nice. Ok...I think it might be time for me to get tires...what yall think?
I got my oil changed this morning and was looking at them before the car got pulled in...probably should get some soon! LoL OH! and that is dirt...not the inside tire lining, I know how it looks! LoL
Old Mar 18, 2016 | 08:16 PM
  #430
the93owner's Avatar
the93owner
Yep looks like they're balding lol
Old Mar 19, 2016 | 12:17 AM
  #431
ChinkyChoy's Avatar
ChinkyChoy
nah just a quick rotate you should be good to go
Old Mar 19, 2016 | 06:48 AM
  #432
IracknBack's Avatar
IracknBack
This is probably a dumb question but oh well.
Is it possible to run a square setup on a 6mt sedan w/o spacers that sits pretty flush?
Old Mar 19, 2016 | 08:51 AM
  #433
You sure can, just check almost all of Chinky Choys sets on the first page. He runs up to a 9.5 +25 on 245s.
Something like a 9.5 +35 all around on 245 to 255 tires will fill the wheel well nicely, with your big Akebono calipers you just need to find wheels that will clear them.
Old Mar 21, 2016 | 02:26 PM
  #434
Mr Nurner's Avatar
Mr Nurner
This looks great! I've been a fan of those V702s a while now, those and the V706s. Good choice again man, looks sweet.
Old Mar 21, 2016 | 04:30 PM
  #435
Strokelessone's Avatar
Strokelessone
How much of a drop are you running, and are you able to keep camber within spec without additional parts/camber kits? I appreciate any info you can give me, really like your set up
