Rubbing help!
Old May 3, 2012 | 10:50 PM
Espig37s's Avatar
Espig37s
Rubbing help!
I'm running 275/30/20 +27 in the rear and I'm on swift springs and keep hearing a scrubbing noise going over larger dips. We trimmed a bit of the fender lining which helped but it's still there. How much do I need to cut. Also, I saw something on here regarding the bumber brackets being bent, how would I do that and could that be the issue? Need to fix this as it sounds terrible and I cringe every time.
Old May 3, 2012 | 10:52 PM
P Casey's Avatar
P Casey
You need to shave your bumper bracket. Dont know how much but that is what your hearing.
Old May 3, 2012 | 10:55 PM
jujubii's Avatar
jujubii
yes its most likely the bumper bracket!
you can do any of these (in order of easiness):
-get superduper stiff coils
-file it down slightly
-remove the screw completely and hammer the tab up (only do this if you arent doing aftermarket rear bumpers in the future) rear shoudl still stay intact
-cut that section with a dremel and relocate the screw
Old May 4, 2012 | 11:13 AM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Tire size is all good, just need to tweak the clearance a bit.
Old May 9, 2012 | 11:37 PM
SoulSeeker's Avatar
SoulSeeker
Yeah i had the same issue then i shaved the bracket and grinded it down and didn't have to remove the screw
Old May 10, 2012 | 11:54 AM
Unique Bliss's Avatar
Unique Bliss
I have oem 19s with 245 front and 275 rear on BC coils w/ SPC camber kits front/back with 20mm spacers all around. I rub all the time on the rear bumper bracket. Can I get enough clearance in the rear if I just hammer up the bracket or does it have to be removed?
Old May 10, 2012 | 12:06 PM
P Casey's Avatar
P Casey
You need to take a dremmel to it.
BurtoN86
Nov 3, 2015 04:40 PM
Soccer4555
Sep 30, 2015 05:31 PM
Heffalump55555
Sep 26, 2015 08:02 PM
botlfed98
Sep 22, 2015 12:30 PM
Simran Mann
Sep 9, 2015 02:08 AM
