any sedans running 20x10 et25?
Old Sep 21, 2015 | 10:20 PM
botlfed98's Avatar
botlfed98
apologize in advance but i tried searching and searching with no luck...
I was wondering if there are any sedans running 20x10 with 25mm backspacing on the rears. I just picked up a set of Ruff Racing 954s that were previously on a coupe 20x8.5 & 20x10 et25 and was wondering if i will have any rubbing issues. I am currently lowered on Swifts with -1.7 degree camber. The wheels have 275/30-20 tires on the back but they are down to the cords and i was wondering if the 275 would be too wide with that offset without rubbing or if i should try a 245/35-20. Any input would greatly be appreciated.
Old Sep 21, 2015 | 11:22 PM
Wheels will poke outside the fenders w/ that camber. Since you already have 275s (even though they're toast) you can still try a test fit just to see how much stretch you'll need. Probably 255s will tuck
Old Sep 22, 2015 | 10:02 AM
botlfed98's Avatar
botlfed98
yeah unfortunately I need different lugnuts to mount the wheels and haven't found any yet, was hoping to find some information here first
Old Sep 22, 2015 | 10:24 AM
ttv36's Avatar
ttv36
Race, repair, repeat.
I used to have Advan RS-Ds at one point (when my car was black) and the specs were 19x9 +25f and 19x10 +25r. I had to stretch and camber like B says. If I recall correctly I had 225s in the front and 245s in the rear with -1.5 camber front and -2.5 in the rear.
Old Sep 22, 2015 | 12:30 PM
botlfed98's Avatar
botlfed98
ah cool, thanks for the info! kinda what I was thinking. That's a lot of camber but looks pretty good
G37xhibeet
Nov 15, 2016 09:29 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
connoisseurr
NorthEast
Aug 29, 2015 08:00 AM
ddayeg37s
Aug 9, 2015 07:10 PM
