Well, here goes nothing... Buh-bye OEM
Old Jul 1, 2016 | 02:16 AM
slartibartfast's Avatar
slartibartfast
You didn't get wrenches with those???
Old Jul 1, 2016 | 07:57 AM
Where did he say that? I'm sure the kit came with two spanner wrenches.
Old Jul 1, 2016 | 08:46 AM
ANMVQ's Avatar
ANMVQ
Originally Posted by bikezilla
Your ride looks awesome in those shots.
I don't plan on slamming, only closing my wheel gap. 1.5-2" or whatever it takes on my SUV looking xS
I got the Fortune Auto 500 coilovers.
I'm kind of surprised that adjustable coil-overs ride differently at different heights. The shock stroke is unchanged, only the body(overall shock length) is shortened.
So Coil-overs ride more harshly the lower they are set?
Thanx man, Too bad I didn't keep them, I was one of the ones who had the horrid knock issue, and couldn't get is solved :/ so I sold them.
Hopefully the fortune 500's work out!
Old Jul 1, 2016 | 10:38 AM
bikezilla's Avatar
bikezilla
Correct sir, the kit came with a hefty pair of wrenches.
It also came with explicit instructions to NOT rely on them to tighten the lock collar.
Old Jul 1, 2016 | 10:41 AM
Pray tell, what should you rely on? Are you expecting to have to check the lock collar every few hundred miles? That will get seriously old the very first time you make yourself do it.
Makes you wonder why the industry doesn't design some kind of immovable locking mechanism between the lock ring and the CO. I'm no mechanical engineer, but really, how difficult could that be?
BTW, Zilla, I think it was a smart move getting the extensions for the rears and poking them through the trunk. In for a penny, in for a pound... and all that. I'm kind of jealous how my Teins don't support damping adjustment, even though I tell myself it's something I would dial in to a preference and never touch again.
Old Jul 1, 2016 | 10:43 AM
bikezilla's Avatar
bikezilla
Hey, I only bought the things, I didn't write the manual.
Old Jul 1, 2016 | 10:51 AM
Wow. Really?
And if that doesn't work, just cut your springs and roll your fenders with a baseball bat.
Old Jul 1, 2016 | 11:25 AM
Hmmmm, I just used the included wrenches w/ mine, about 50k miles and still tight.
But if they make a special note to do it that way, then there must have been problems.
Old Jul 1, 2016 | 12:27 PM
bikezilla's Avatar
bikezilla
Perhaps it is similar to the legal protection in the same way the manual states these coil-overs must not be used on public roads.
Old Jul 1, 2016 | 01:29 PM
Yep, all these aftermarket parts are for our annual G37 sand buggy runs
Which reminds me, need to order those new sand tires.
Old Jul 1, 2016 | 02:08 PM
bikezilla's Avatar
bikezilla
Ah!
Well that explains the awesome wheel clearance!
Old Jul 1, 2016 | 06:15 PM
G37xsfun's Avatar
G37xsfun
Front on my sedan with fender at 26.25 to ground
Rear on my sedan with fender at 26.25 to ground
Old Jul 1, 2016 | 07:47 PM
bikezilla's Avatar
bikezilla
Excellent, thanks!
QQ: Did you have to remove your front AWD axle to install the shock as the FSM states?
Seems to me that's a lot of work to swap a shock.
Old Jul 1, 2016 | 09:04 PM
  #29
G37xsfun's Avatar
G37xsfun
No, if you remove the sway bar to lower control arm it will droop enough.
Old Jul 1, 2016 | 09:09 PM
  #30
G37xsfun's Avatar
G37xsfun
https://www.myg37.com/forums/d-i-y-i...l-on-an-x.html
