Tein Basis Coilovers? Yes, no?
damn those tires are thin. looks great tho. u gotta expect a harsh ride with that no?
Im on the Teins, 26.25/26.5 if that helps, no real scraping unless its an extreme downward angle. As far as suspension travel, in terms of comfort this rides like OEM to me at this height. Most people run this height to kill wheel gap and to remain good at daily driving, seems to be the general consensus around here.
How easy is the install on these? Mine are supposedly at my house right now; I'd like to knock it out after work. I have an impact gun + torque wrench and have done a lot of suspension installs before. Car only has ~45K miles and is from Alabama so I'm hoping it's not too jammed up. Can I knock it out in a weeknight? I have to do all 4 corners in one shot.
Front seems pretty simple too, outside of having to use the spring compressor to get the top hat off. All the bolts seem pretty easy to get to, even with the impact gun. I might take a look at it tonight if I have a second.
it needs time to settle. u should give it a conservative drop until it settles then lower to ur liking then get the alignment. i would say give it 2 weeks to settle at least but u said u did that before with ill effect. were u slammed? i waited longer and nothing happened to my tires. its up to u
It had struts up front (8th gen) so it was more sensitive to toe. Mild drop (1.5"). Same story with my Maximas. But the DWB Accords didn't need alignments at all from what I remember. Hopefully the G isn't super sensitive.
