CUSCO strut questions
Old Apr 22, 2014 | 10:53 PM
Vance67's Avatar
Vance67
Si I bought the CUSCO strut bar and installed it tonight.
I have a couple of questions I couldn't find the answers to:
1) I tightened the nuts on the brace as hard as I could to the strut, is that how it should be
2) I Also tightened the strut bar as much as I could to the braces, is that how it should be or should there be some play in it?
3) & finally, how much does it rub into the heat shield? will it cut into? Is it really worth it? I haven't driven it yet, since its raining.
Thank you for any help you can give
Old Apr 22, 2014 | 11:19 PM
cecrops's Avatar
cecrops
On the DIY for the strut brace:
Originally Posted by simpson_G37X
just found the specs
it is 37.5 N.m, 28 ft.lb
Old Apr 22, 2014 | 11:26 PM
Vance67's Avatar
Vance67
Ya, I thought I saw that, but when I searched again, I couldn't find it.
Actually 26lbs, so happy you wrote that
any idea about the strut bar to the braces?
Old Apr 22, 2014 | 11:53 PM
cecrops's Avatar
cecrops
I don't, but it's up there on my mod list so I will need to know too. I was just going to tighten them like you did and make sure not to strip anything.
Old Apr 23, 2014 | 12:24 AM
G37_Gio's Avatar
G37_Gio
What benefits of having the strut installed to your car have?
G37_Gio's Avatar
G37_Gio
What are the benefits of having a strut bar?
Old Apr 23, 2014 | 10:07 AM
dkmesa350z's Avatar
dkmesa350z
lol these questions would have been good before installing. torque specs are located in the FSM, but I want to say 50-60 ft lbs.
Old Apr 23, 2014 | 10:31 AM
Vance67's Avatar
Vance67
LOL, ya, I should have asked first, but it's on of my first mods for the handling and in general, so I saw the box when I got home, ripped it open and installed it. I may have tightened them so much I bent the braces a little...dammit.
What is FSM? Something service manual? Cause I did get the ft lbs for the struts, but now was wondering how tight to tighten the bar to the braces? I figured just as tight as I could without stripping it. A coworker here has a Subaru WRX that is completely modded and he said that's how he did his, as tight as he could
Old Apr 23, 2014 | 11:10 AM
Dough1397's Avatar
Dough1397
FSM = Factory Service Manual
Enjoy!
Old Apr 23, 2014 | 11:14 AM
Vance67's Avatar
Vance67
Originally Posted by Dough1397
Thank you, I do have that in my subscribed threads and should have checked it (someones an idiot...this guy)...this is probably a stupid question, but it won't have how much I need to tighten the actual strut bar to the strut brace would it? Not the strut brace brackets to the strut, but after you remove the bar to install the brackets on the strut, you need to re-install the bar to the brackets on the strut. How tight do I tighten the actual bar to the brace? Does that make sense? I haven't looked at the FSM, but I will now.
Thank you
Old Apr 24, 2014 | 05:16 PM
GTLAW's Avatar
GTLAW
You don't need that shield under the hood. I took mine off after 25 miles and it's fine. It's more for sound then heat.
Old Apr 24, 2014 | 05:30 PM
Vance67's Avatar
Vance67
ya, I brought my car in to work to get all my fluids changed (Coolant, Brake, Clutch, Differential, Transmission, Power steering and Engine Oil), $552 later...I asked my techs about the shield and they said I'm good. Same thing, it's not really there to protect the paint like I thought
kavcheung
Jan 22, 2016 02:40 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
Mattlorentzoe
Sep 14, 2015 07:32 PM
Falker11
Sep 9, 2015 08:53 PM
mmnjtwa
Sep 7, 2015 02:27 PM
