Coilovers Installation (Need help) (Pics)
Old Dec 27, 2012 | 05:29 PM
Hooray! LOL. Be sure to spray the other one down really well and let it marinate overnight.
Old Dec 27, 2012 | 09:04 PM
IAmYourPal's Avatar
IAmYourPal
Lucky for me I have an impact gun. It came out super easily even though my car has 60,000 miles when I did this. But then again I live in CA so there is no salt.
Old Dec 27, 2012 | 09:28 PM
TVPostSound's Avatar
TVPostSound
I must be the only person ever to work on a G37 suspension who hasn't had trouble with this particular bolt. I have done 15 or 20 spring/coilover installs on these cars and never rounded one off or even had to use more than moderate effort. Even when I used hand tools rather than an impact gun. Lucky me.
Yes Sal can get that off for you. If you live anywhere near Baytown, I will do it for you. BTW, where did your car come from? That car has not been in Houston for all of it's 37K miles. That's a lot of rust.
Nope, you're not the only one. I have a Snap-On 3ft breaker bar, 6 point metric impact sockets, and if thats not enough, the floor jack handle as another 3ft extension!!
Old Dec 28, 2012 | 12:13 PM
Fentress24's Avatar
Fentress24
I bent a 3ft steel breaker bar and used an electric high power impact gun that I had to put on high to get it off. Glad I had that laying around. This bolt is a beotch. I got the rears done in like an hour and the fronts took forever because of this bolt and re-using the stock top hats with the tanabe's.
Old Dec 28, 2012 | 12:36 PM
You are lucky. Most electric impact guns done have nearly enough torque for this bolt.
A good lubricant, heat, and a lot of properly applied force seems to be the recipe.
This is the best penetrating lube I have ever used. Blows Liquid Wrench, WD40, and even PB Blaster out of the water. I use it just for the really tough stuff like this bolt because it's expensive.
Penetrating-Lubricating Oils
Old Dec 29, 2012 | 05:46 PM
SwissCheeseHead's Avatar
SwissCheeseHead
Normally I would advise this: Heat it with a heat gun. Spray it liberally with PB Blaster or Kroil. Let it soak overnight. Respray it liberally. Use an impact gun.
However you have screwed it up by rounding it off. Take the same steps, but instead of using an impact gun, you'll now have to use a damaged bolt extractor. They will cut into the bolt head to grip as you apply pressure. It is ruined, and you'll have to replace that bolt. Use a breaker bar at least 1/2" drive and at least 2' long. Like this one:
1/2" Drive 25" Breaker Bar
Damaged bolt removers:
Judging from the amount of rust visible, I'm guessing you live in a harsher northern climate. My 96 Maxima doesn't have that much rust on it. That's part of the issue making it harder for you. Good luck.
Yes. this is how it's done. With 46K miles on mine I didn't have any issues with any bolts. Use a propane torch and a penetrating fluid of choice with a breaker bar and it'll come off easy as pie.
si_driver
Aug 23, 2017 01:35 PM
BANNISTER
Dec 10, 2015 04:14 PM
sLADe781
32
Nov 28, 2015 03:23 AM
JakeG37
Aug 13, 2015 11:19 AM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
