BC Coilover question:
Old May 28, 2008 | 03:32 AM
Xander's Avatar
Xander
Got them installed a couple of weeks ago, and the back end rattles, when going over bumps.
The shop I got them installed from said that it was because of the spring design being metal on metal.
I dunno but I want it gone. What do you guys think?
Thanks
Old May 28, 2008 | 07:58 AM
Blackjack's Avatar
Blackjack
Thanks
Hmmm... Doesn't seem right. I know 2 people with BCs that I've seen personally and they don't rattle.
Old May 28, 2008 | 08:40 AM
IP37's Avatar
IP37
where did they run your extenders? it could be them rattling if they're just tucked behind the carpet or something
Old May 28, 2008 | 09:07 AM
Xander's Avatar
Xander
no, they didn't put the extenders in, as they didn't have easy access to the trunk because of my fibreglassing
Old May 28, 2008 | 09:16 AM
IP37's Avatar
IP37
and actually.. the spring shouldn't be touching any metal now that i think about it. did they put them in right?
the cone-shaped top coil perch comes out and gets replaced with the piece that came with the coilovers (pretty sure it had rubber on it)
and the bottom rubber piece gets taken off of the old spring and put on the new one
i'd check and make sure all the bolts were tight too
Old May 28, 2008 | 09:23 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^Exactly. You should have no noise what so ever.
Old May 28, 2008 | 09:24 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
My Rear Right Rattles some... I have tried to see why and adjust a lil but no luck... I am going to have Sharif take a look at it in 2 weeks when Im down there...
Old May 28, 2008 | 10:18 PM
1BADV6's Avatar
1BADV6
Glad I'm not the only one with the rear right rattle...it sounds like something loose and is ANNOYING! I thought it was my seat not fully latched or the seat belt in the back hitting the trim, but it is neither. Sadly I noticed that with a passenger the noise goes away, making this really difficult to resolve. Let me know what you find Max.
Old May 28, 2008 | 10:23 PM
MaxToTheG37
Wow.... Thats a ditto here... Sharif thought it was stuff in my trunk also... when i got back home I messed with it... rode with a passenger and thought I fixed it... but nope... hmmmm... Pete may need to get in on this
Old May 28, 2008 | 10:34 PM
sumo8me's Avatar
sumo8me
I have the same problem
Old May 29, 2008 | 12:10 AM
Xander's Avatar
Xander
I thought it was just me. So its nothing we can resolve ourselves?
Old May 29, 2008 | 12:14 AM
TerribleONE453's Avatar
TerribleONE453
hmmmm this makes me not wanna buy them...
Old May 29, 2008 | 12:35 AM
finagle69's Avatar
finagle69
... I just did!
Old May 29, 2008 | 12:37 AM
VRG37S's Avatar
VRG37S
Well hopefully you don't have the same problem with your set of coilovers. That would suck big time.
Old May 29, 2008 | 01:02 AM
gan78mao's Avatar
gan78mao
hmm
seems like theres alot of problem with the BCs
kinda glad i didnt jump on it!!
