Painting my grill ??
Old Apr 24, 2015 | 03:30 AM
buggzg37s's Avatar
buggzg37s
Originally Posted by NickyP
Did you sand down the grille first, or paint right over the chrome?
I had some chipping towards the top of the grill so YES I wet sanded the whole thing with 220 grit sandpaper until is was completely smooth. Well worth it.
As for those who are saying the grill removal is a pain the the a$$ it's worth the 10 mins to remove it. It's like 8 screws and 15 clips. There is a really good write up that some one did on how to remove the grill and that's what I followed made it super simple. The link is below.
DIY: Grille Removal - G35Driver
Good luck to you.
Old Apr 24, 2015 | 04:32 PM
blackstorm's Avatar
blackstorm
Originally Posted by axis.
Aren't you concerned about plasti dip hitting your radiator?
I want to plasti dip my grill too and saw how much of a hassle it is to remove the radiator cover, which looks like a pain. I'd much rather just spray directly onto the grill but I don't wanna cover my radiator in plasti dip...
Anyone chime in?
I didnt get a single drop on my radiator. It all depends on how your spraying it on. Your supposed to keep the can 6-8 inches away from the surface your spraying, and your supposed to coat it very lightly each time. Also I sprayed it on a downwards angle from above the bumper down onto the grille. Hope this helps!
Old May 2, 2015 | 10:46 AM
trippingjimmi's Avatar
trippingjimmi
I plan on spraying my grill Black next month, and will be leaving the grill on the car as well. I was just wondering, I don't want it to be fully matte black, like the plasti dip, but rather a bit of a glossy black, anyone know how I can achieve this look? Just spray a clear coat over the plasti dip?
Old May 2, 2015 | 11:15 AM
NickyP's Avatar
NickyP
I didn't trust myself to leave it on the car so I pulled it off. Just finished my last coat (5 coats) and waiting for at least an hour before putting it back on the car and a few more hours before driving. I would have only done 4 coats but had some bubbling on the second that I had to lightly sand down and it looked like it needed the last one.
Its not perfect but it looks better than chipped chrome and I can redo at a later date if I want to, but Nopi Nationals is this weekend and the monthly car show is tomorrow so I wanted her to be "good enough."
Old May 5, 2015 | 09:19 AM
blackstorm's Avatar
blackstorm
There is supposedly a Glossifier you can use to achieve that affect. You spray it on after your matte plasti dip has dried, but i have never used it, nor seen anyone use it, so i am not sure how effective it is.
Glossifier
Old May 5, 2015 | 12:33 PM
guy from norcal's Avatar
guy from norcal
Glossifier
The glossifier works good. Basically the more you put on,the shinier it gets.
Old May 11, 2015 | 01:17 PM
calebshill's Avatar
calebshill
You can use the Glossifier.....it does fade over time so just expect to reapply every once in a while.
rk325
Dec 8, 2020 08:14 AM
beng37s
Dec 8, 2019 01:21 PM
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
ck1109
Oct 15, 2015 11:06 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
