Reverse lights wont work!
Old Dec 26, 2014 | 12:05 PM
staaksondeck's Avatar
staaksondeck
i replaced my reverse lights with LED's because i thought it was maybe a coincidence that both bulbs went at the same time but both bulbs STILL dont work. ive seen that the 6MT has a relay ONTOP of the tranny but the AT still rely on a fuse? funny because i CANNOT find a fuse for the reverse lamps unless there is more fuse boxes than the one by the stomp pedal and the one by the battery....please somebody help, i am losing my mind over this.
'09 g37x sedan auto.....
Old Dec 26, 2014 | 01:42 PM
e3phung's Avatar
e3phung
Did you buy pretty decent LED? I remember having to messing around with the license plate led because it kept wiggling loose. sometimes the LEDs just cant get a solid connection or could possibly be bad. Try testing the LED and making sure they are good to go.
Old Dec 26, 2014 | 02:52 PM
telcoman's Avatar
telcoman
Have you tried testing with a voltmeter and the FSM?
It is only Battery and ground
Telcoman
Old Dec 26, 2014 | 05:21 PM
alrockaz's Avatar
alrockaz
Try turning the LEDs 180 degrees in the socket - the polarity may be backwards and Murphy's law would suggest both might have made it in backwards. I doubt it's a bulb issue but this would be an easy first step.
For troubleshooting I would recommend going back to new traditional incandescent bulbs until you figure it out just to rule out any issues with the LEDs.
Old Dec 26, 2014 | 06:47 PM
G37Xtreme's Avatar
G37Xtreme
Is someone telling you they aren't working?
I upgraded to LED recently, and assumed they weren't working either. I expected them to be much brighter, and what I saw out of the backup camera indicated that maybe they weren't working.
I finally mustered the courage to put it in reverse (uphill) with parking brake on, then I walked out and looked. Sure enough, they were both working.
I've come to realize that they do provide good light, I just had larger expectations.
Old Dec 26, 2014 | 08:19 PM
ay37's Avatar
ay37
To the op, as alrockaz said, try flipping them 180 degrees. Usually, that's the case and make sure they fit into the socket tightly. Most LED's are have one-way polarity, meaning the current only travels in one direction. Unlike regular bulbs which you can put in either way. If you notice on the LED bulb, most likely it only has one lead on each side of the bulb, whereas regular bulbs have 2 leads on each side of the base of the bulb. Good luck!
just turn ignition on without starting the car, and it will let you shift into any gear... put it in reverse and walk out back to check. LOL you took a dangerous approach testing those!
EDIT: I have these reverse LED bulbs and they are SUPER BRIGHT for anyone interested... they really light up the back of the car at night and you can see everything clearly in the camera... much much better than stock. http://www.ebay.com/itm/281386340147?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Dec 26, 2014 | 08:51 PM
DeepakG37's Avatar
DeepakG37
Sometimes if you insert the LED backwards it wont work, flip the inserts and re-install.
Old Dec 27, 2014 | 10:36 AM
EG Ryan's Avatar
EG Ryan
I think staaksondeck said both his OEM backup light bulbs stopped working before he put in the LED bulbs.
Anyone aware of the fuse for the backup lights?
Old Dec 27, 2014 | 11:35 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Looks like fuse #4 on the in-cabin block - but I don't think your guages would be working if that were blown... Polarity is the first thing to check.
Old Dec 27, 2014 | 06:08 PM
staaksondeck
Yeah EG Ryan is right...the regular bulbs didn't work either and they weren't blown either. I will try to flip them 180 and see if that works because I noticed some of the other leds were like that but still 99% sure there's an actual issue other than the bulbs just being out in backwards
Old Jun 28, 2020 | 03:37 AM
Steezysil's Avatar
Steezysil
Same problem bulbs work but reverse lights still not coming on
Anyone figure it out I’m having the same problem. And where exactly is the fuse/relay for the reverse lights on a auto. I looked everywhere
Lt8Che
91
Apr 8, 2022 04:55 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
warpeacelove
Oct 28, 2015 02:59 AM
MJ HINX
Aug 23, 2015 10:30 PM
Skeletor06
Aug 2, 2015 12:54 AM
