Foglights Will Not Turn On
Old Sep 24, 2013 | 03:58 PM
IAmYourPal's Avatar
IAmYourPal
Hey guys,
I recently hooked up my IPL bumper foglights with HID fogs and also hooked up the foglights in my OEM headlights with HID too. They worked when I turn them on individually but the other day I turned them both on at the same time now both of them will not turn on.
I checked some fuses under the hood and driver's interior but none of which were blown. IPL bumper foglights is ran through a relay harness with a switch.
Everything in my car works fine except for these foglights. Anyone ever tried something like me and this happened?
Any help would be appreciated. Thanks.
Old Sep 24, 2013 | 05:36 PM
Diode Dynamics's Avatar
Diode Dynamics
How did you wire them up? Do you have any pictures I can look at for reference?
Nick C.
Old Sep 24, 2013 | 07:19 PM
IAmYourPal's Avatar
IAmYourPal
Well the foglights in the existing headlights are wired through the stock wiring. The ones on the bottom in the bumper is wired through a relay harness going to the battery with a fuse. It goes into a switch inside my car to allow me to turn it on and off.
Old Sep 24, 2013 | 07:26 PM
IAmYourPal's Avatar
IAmYourPal
I apologize for I do not have pictures. I wired the bottoms fogs as shown in this thread. https://www.myg37.com/forums/d-i-y-installations-modifications/230543-2011-non-sport-fogs-on-2008-2010-sport-bumper.html
Old Sep 24, 2013 | 08:11 PM
IAmYourPal's Avatar
IAmYourPal
I found the 15A fuse for foglights that's inside the headlights and it was blown. I replaced it with another 15A and it blew too. Switched a 20A fuse in there and it works fine. Is it safe to use the 20A fuse in place of the 15A? Or should I invest in another relay harness so I don't risk melting the stock wiring?
Old Sep 24, 2013 | 09:07 PM
Yan141's Avatar
Yan141
What brand and watt HID kit do you have?
Old Sep 24, 2013 | 09:37 PM
IAmYourPal's Avatar
IAmYourPal
I have 35W Morimoto bulbs. One set is paired with DDMTuning ballasts and the oter uses. Hyluxtek ballasts.
Old Sep 24, 2013 | 10:41 PM
Yan141's Avatar
Yan141
35w should be fine, but I would upgrade your ballast and relay. Just to be safe.
timc00k
Feb 15, 2017 09:15 AM
Rybitron
Nov 18, 2015 03:11 PM
parkern
Oct 1, 2015 10:15 PM
Landshark
Sep 29, 2015 11:20 PM
MrRiv
Sep 29, 2015 04:59 PM
