Project Completed: Folding Side View Mirrors
Old Jan 25, 2015 | 03:15 PM
  #91
connoisseurr's Avatar
connoisseurr
Resurrecting this thread.
I completed the install on my sedan and am looking for information on hooking up the power fold module.
ModMe - I sent you a PM asking about the wires you tapped to get the power fold to function properly. Any help on this?
Did anyone else successfully install this module and has it working properly? I have the module and associated wiring, just need to figure out how to hook the damn thing up. Tried testing different voltages within each wires during certain function but that did not work as I had expected.
Old Nov 9, 2015 | 06:54 AM
  #92
INFINITG37BOI's Avatar
INFINITG37BOI
my mirrors don't auto fold...ahhh
So bringing back and old thread again..my mirrors aren't folding after a body shop messed with door panel.. I thinking a fuse blew..cant locate fuse..can someone help me with the fuse location?modme? Thanks
Old Nov 9, 2015 | 09:06 AM
  #93
ILM-NC G37S's Avatar
ILM-NC G37S
On my setup, I tapped into the power window switch to get power to the folding mirror circuit.
If possible, I would double check the wiring harness in the door to make sure everything is tight and secure. There a couple of fuses you could check as well. I'm sure it is something simple.
Good luck!
Old May 1, 2016 | 11:46 PM
  #94
gnewbie's Avatar
gnewbie
..." The mirror covers are also perfect swap with the coupe's."
So does that mean the covers are removable, and you can use the covers from your coupe's "manual folders" if need be?
I can probably find the infiniti OEM parts at a reasonable price. Its getting things painted to match, etc., that would jack up labor costs if I wanted to do this.
Old May 3, 2016 | 12:27 PM
  #95
ILM-NC G37S
The mirror covers are the same for both the coupe and the convertible. I reused my covers when I swapped to the convertible mirror assemblies.
OEM part numbers:
Left side: K6374-JL00A
Right side: K6373-JL00A
Both are about $52 each on amazon as of today but you might find them cheaper elsewhere.
If I recall, they come primed but not painted. You would have to get them painted on your own.
Old Sep 17, 2016 | 05:09 PM
  #96
DJMAC's Avatar
DJMAC
Just a heads up if anyone is trying to install the auto fold module with this mod I have a DIY.
https://www.myg37.com/forums/d-i-y-i...e-install.html
Old Oct 2, 2016 | 11:11 AM
  #97
DJMAC's Avatar
DJMAC
Also if anyone needs the male terminal wires for the harness (J-48817-217)i was forced to order a bunch and pay a ton for shipping. If anyone wants to get any inbox me and I can mail them out, $10 bux and I will put them in an envelope.
Mac
Amaadkhan2k
Oct 4, 2024 01:20 PM
Victory
17
Oct 27, 2022 03:45 PM
eljoker
Future Models
19
May 30, 2022 11:48 AM
RichardMiami
Apr 24, 2019 02:19 PM
Raleclair
Oct 8, 2015 02:06 PM
