FREE headlight conversion consulting
Old Sep 14, 2011 | 05:33 AM
tWistedMissiOn's Avatar
tWistedMissiOn
Danny! You are the man!! Wow, i am loving this forum more and more! Showed me that true enthusiasts still exist!
Weiboy, you have been great at helping me with most of my mods, and your credits won't go wasted. So its only right that i say it out again "THANK YOU"!!
Useless thread is dominating because that's where most of the true enthusiasts lurks... or just people with bunch of free times hahaha
Old Sep 14, 2011 | 12:05 PM
kchu221's Avatar
kchu221
thanks for the help! ive only heard good things about your products!
Old Sep 14, 2011 | 12:32 PM
ucla bruin's Avatar
ucla bruin
Originally Posted by daicon0
thanks for offering your service! and for free! that's priceless!
I have a question about taking out and putting back in the HID light from our headlights. what tool(s) and/or method do you use?
after painting the housing of my headlights; I found putting the HID light back into the housing the most time consuming and pain in the ****. Thanks for your input and/or recommendations!
Not a problem! Assuming you're referring to the actual bulb, it is difficult to putting it back because of the small HID opening. Try using a pair of pliers (alligator or something slender), use it to hold the HID and inserting it. Be sure to tighten the HID connector until it "clicks".
__________________
Old Sep 14, 2011 | 12:34 PM
ucla bruin's Avatar
ucla bruin
Answered all the PMs.
It's nice to see that a lot are coming from So Cal but am glad you'll be attempting it on your own. It'd be great too if you guys can post it here so other members can benefit from your question as well.
__________________
Old Sep 14, 2011 | 03:10 PM
Djfarhan's Avatar
Djfarhan
Old Sep 14, 2011 | 03:38 PM
daicon0's Avatar
daicon0
Click? I don't remember any parts to click to. It has groove patterns to match then a clamp to hold it there... Hmm, maybe I missed it, i might give it a go this weekend! Thanks for the advise!
Old Sep 14, 2011 | 04:11 PM
ucla bruin's Avatar
ucla bruin
No, you got it right. Match the groove then clamp it down. Then connect the power cable, turn it until it clicks.
__________________
Old Sep 14, 2011 | 04:47 PM
daicon0's Avatar
daicon0
Bummer... I was really hoping that it clicked on/off, now I don't know if want to take it out anymore... ... I probably will! Thanks Danny!
Old Sep 14, 2011 | 07:56 PM
jujubii's Avatar
jujubii
hey danny, i was wondering if you knew the answer to this.
its a double post cuz i dunno if anyone really reads the diy section anymore lol
https://www.myg37.com/forums/3231450-post169.html
Old Sep 15, 2011 | 10:24 AM
Weiboy718's Avatar
Weiboy718
Originally Posted by ucla bruin
Post links to the surface mount and I'll check it out for you. You can get them from anywhere. Surface mounts are not as inconsistent as through-hole (the common cylindrical ones). Parallel is "better" because all LEDs will be at the same brightness but you will run a lot more power -> melt something or blow something. So if done right, parallel. Otherwise, series is safer but each load may have different brightness. There's a lot more to this than I can explain in a paragraph. Take away is: it depends on what you're using and how many LEDs.
Just following in your footsteps!
Originally Posted by RYs06MT
Nice thread Danny.
Thank you for every PM you've answered of mine and your contributions to our forums.
All of our clearance lights uses 168 bulb and the green box is correct. There's only 2 location for The clearance lights.
Old Sep 15, 2011 | 11:57 AM
ucla bruin's Avatar
ucla bruin
Yea, what Weiboy said. Green box is the amber reflector bulb. Turn it left 45 degrees and pull straight out. Let me us know if you have any other questions. GOod luck!
__________________
Old Sep 16, 2011 | 01:19 PM
Kuro's Avatar
Kuro
What do you think about demon eye and ironman? They wouldn't last long or it depends on your luck
Old Sep 16, 2011 | 01:38 PM
Weiboy718's Avatar
Weiboy718
the demon eyes def will not last if the headlights are on at the same time unless you add a on off switch. Led's are like hit and miss sometimes. Some will last some won't. If you can do your own work I'd say go for it.
Old Sep 16, 2011 | 02:09 PM
  #29
ucla bruin's Avatar
ucla bruin
Define long?
But generally, they will be more headaches than it's worth. Also not worth the money IMO, that's why I stopped offering it. I think it looks bad and devalues the car when you just have 1 LED out too, cheapens the feel and takes away the class. Of course, this is all my personal opinion as an enthusiast and past vendor.
FYI, Audi has an entire cooling mechanism behind their DRL LEDs to cool them so they last. Unless you're getting something similar, I would say don't bother. LEDs and heat do not work well together. It's also the fact that they have to be meticulously integrated into the light makes them difficult to maintain/repair -> which translates to high cost for you.
For those that have PMed me regarding painted headlights, the shops I recommended will do more than take care of you. Lowest pricing you can find as well. I believe that's the missing piece for a lot of people.
__________________
Old Sep 17, 2011 | 12:30 AM
  #30
Kuro's Avatar
Kuro
Thank you Weiboy for your info
Define long?
Thank you Danny, I've been curious how Audi offer their headlight with no issue now I know.
