FREE headlight conversion consulting
#31
Define long?
But generally, they will be more headaches than it's worth. Also not worth the money IMO, that's why I stopped offering it. I think it looks bad and devalues the car when you just have 1 LED out too, cheapens the feel and takes away the class. Of course, this is all my personal opinion as an enthusiast and past vendor.
FYI, Audi has an entire cooling mechanism behind their DRL LEDs to cool them so they last. Unless you're getting something similar, I would say don't bother. LEDs and heat do not work well together. It's also the fact that they have to be meticulously integrated into the light makes them difficult to maintain/repair -> which translates to high cost for you.
For those that have PMed me regarding painted headlights, the shops I recommended will do more than take care of you. Lowest pricing you can find as well. I believe that's the missing piece for a lot of people.
#32
I am trying to figure out a wiring schematic for my M,
I am running quad projecors.
(MAIN) Single Low On/Off
(Secondary ) On / Off + High
How the heck can I do this?
Either I can make it work permantly with the low beams all 4 all the time + high with trigger.
Or low beams on & off
And Highbeams on as normal.
How can I get the 1st option to work?
#33
What's the stock form for the M? Just dual projectors not quad right? Or does it come with quad from the factory and you're trying to install 2 additional projectors?
Can you rephrase?
__________________
Can you rephrase?
__________________
#34
its nice that you are doing something like this. Good help is hard to find, a forum is great but sometimes the information is scattered...but being able to call up one person and get some help is really important.
#36
Who can you recommend to do a tsx lens swap and also retrofit something like the morimoto projectors for example,into the fog light area on a 09 coupe? And paint the headlights ofcourse
#37
hey danny, i know these aren't exactly in the headlight but i was wondering if you know anyone who can do this mod and if that metal bar is necessary under the LEDs: https://www.myg37.com/forums/picture...e-top-ten.html
#38
Have you tried PMing him? I haven't seen his car in person although we live in the same general area, but from what I've heard, it looks very clean.
The metal bar may not be necessary depending on how the LED bar is designed.
__________________
__________________
#39
hey danny have you ever put a 55x ballast in for our headlights so our headlights are brighter? i was thinking of doing that and i wanted to know if our headlights can handle a 55w ballast. thanks
#40
Hi Danny, do you have any recommendations on how to properly clean the underside of the clear piece of the headlights? I'm talking about the clear piece that is pried off to gain access to the housing pieces. Correct me if I'm wrong but the underside doesn't have any protection so it can easily scratched but honestly it got so dusty from when I painted the housing a few months back that it's really bothering me. I tried some armorall glass wipes when I took apart one side last weekend but that didn't do much plus I didn't apply much pressure anyway when I wiped. Thanks for any help!
#41
What do I need for LED turn signals? I know I'll need a load resistor or something like that of some kind so they don't blink super fast but what kind? V-LEDS has two options. One is 3ohm the other is 6ohm. My blinker housing is painted black with the rest of the lights and the stock turn signal bulb just is not bright enough.
Thanks
Thanks
#42
Thanks
Thanks
__________________
#43
They will fit the G37 headlight right?
On the FAQ on v-leds site for LED turn signals it says this:
Load Resistor Kits:
One pair 6 Ohm or 3 Ohm, 50 Watt resistors can be connected across the turn signal wire to simulate the load of regular filament bulbs. This will solve LED related turn signal problems such as hyper flashing, no flashing or burnt out bulb indications. Two 6 ohm resistors equals 2 standard filament bulbs. One pair 3 ohm resistor equals the load of 4 standard filament bulbs. Each kit includes two resistors and 4 gel filled moisture resistant splice taps.
#44
I live in nebraska, so hot *** summers and cold as winters.
My goal is newest ironman mod, demon eye mod, and led sidestrip turn signals. Do you think I will have problems with this set up in the weather I get? Car will be a DD year round.
Thanks for all the help you give.
#45
Same here, I figured out my wiring issue, So how the hell do you wire the ironman LED's I want to do something simular and I cant seem to figure out the wiring of the leds.. Help sir...
