IPL/Aerodynamic Bumper Swap Idea.
Old Jan 24, 2012 | 10:10 PM
  #1066
BlkG-37S's Avatar
BlkG-37S
Originally Posted by BooSa37
^^i told you, brad told me personally the vents without the holes were not sold separately. You either need to search on eBay or yunk yard.
Well, that sucks. Wish I knew that prior before ordering everything. Guess I'll have to fork more cash and buy all the fog light parts since going non-fog will be difficult. Sigh...
Thanks for the info BooSa.
Old Jan 24, 2012 | 10:19 PM
  #1067
sick6speed's Avatar
sick6speed
I'm still stumped. It looks like something that might belong to the bumper b/c there's a "RH" "LH" part....does anyone know what these are for?
Originally Posted by sick6speed
Hey guys,
Just got my bumper in. Give a call and make sure you talk to Glenn...great guy and he will always return voicemails!
2 thinkgs: I got the bumper in MW...should I black out that chrome around the foglights? I know it stands out a lot on the other colors but it really blends in w/the white. I've already gotten a blacked out grill w/white emblem (180 custom) but my rims are black w/polished lip.
Also...all the extra parts that came w/the washer tank...do I need all that? Looks like 2 black strips and another piece. I thought it was just unscrew one tank and put the other one in. Haven't had a chance to pull the car apart yet. Just wanted a heads up before I do.
Thanks!
Old Jan 24, 2012 | 10:23 PM
  #1068
BooSa37's Avatar
BooSa37
Yea bro I was on the same boat as you when I decided to do the swap. Trust me is better to have the fogs.
Old Jan 24, 2012 | 10:25 PM
  #1069
BooSa37's Avatar
BooSa37
That's the front tag bracket. N the other two parts are small splash guards, goes under the bumper somewhere. I didn't bother to install, I don't think nobody has.
Old Jan 24, 2012 | 10:41 PM
  #1070
BlkG-37S's Avatar
BlkG-37S
BooSa, could post a final reply on the additional parts I'll need to complete the swap and where you personally purchased them? I currently have the front bumper, IPL sides, and black replacement rings.
I know I'll need the washer tank and fog lights, where did you purchase them? Also, do I need to order anything else in additional, wiring, brackets, etc? I want to order the remaining parts and be done with this. Let me know and all your input is very much appreciated. Thanks again.
Old Jan 24, 2012 | 10:53 PM
  #1071
Trunks333's Avatar
Trunks333
1) Fogs
Left and Right
Amazon.com: TYC 19-5720-00 Nissan Sentra Driver Side Replacement Fog Light: Automotive
Amazon.com: TYC 19-5719-00 Nissan Sentra Passenger Side Replacement Fog Light: Automotive
2) Washer Tank
Infiniti parts
3) Pigtails for the H11 Foglights
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Jan 24, 2012 | 11:21 PM
  #1072
BlkG-37S's Avatar
BlkG-37S
Trunks!!! Super clutch of you my man. Thanks for feedback and links. I needed hand holding, so I appreciate it. Going to place orders now. Thanks again bud.
Old Jan 24, 2012 | 11:32 PM
  #1073
Trunks333's Avatar
Trunks333
Np.
Do you want to also use your original fogs? 4 foglights? If not, all you need to do is cut the wires going into your headlight fogs, then connect them to the ends of the pig tails.
Here is an image of the back of the headlight. You need to cut the wires in the blue circle, connect black to black, blue to yellow (From the pigtails).
Old Jan 24, 2012 | 11:39 PM
  #1074
TVPostSound's Avatar
TVPostSound
I have a DIY on wiring if you want to do it right:
https://www.myg37.com/forums/d-i-y-i...rt-bumper.html
The fog lights are the same, as is the wiring.
Part #s are included.
Old Jan 24, 2012 | 11:47 PM
  #1075
BlkG-37S's Avatar
BlkG-37S
Originally Posted by Trunks333
Np.
Trunks, I bought all the parts you posted...literally. I have an 08 with no fogs. You sure this wiring harness is all ill need to connect and run the fogs?
Old Jan 24, 2012 | 11:51 PM
  #1076
Trunks333's Avatar
Trunks333
Your 08 has fog lights. They are integrated into your headlight. They are not separate like on 2010+ coupes. The blue circle in the picture is where the headlight fog is located. All you need to do is cut the wires and connect them to the fogs on the bumper via the pigtails.
Old Jan 24, 2012 | 11:58 PM
  #1077
BlkG-37S's Avatar
BlkG-37S
Got it. Learned something else about my car today. Didn't know they were intergrated into my head lights in he 08.. How would I activate the fogs? Will they turn on every time I turn my head lights on or can I have them run separately? Seems easy enough to install, thanks that to illustration.
Old Jan 25, 2012 | 12:06 AM
  #1078
Trunks333's Avatar
Trunks333
Fog light switch. Its a switch you turn right next to the headlight switch.
Old Jan 25, 2012 | 09:00 AM
  #1079
hywel's Avatar
hywel
So there's the front license plate bracket, and the two plastic strips go to fill the gap that now shows between the wheel liner and the edge of the bumper because the aero bumper is wider on the bottom than the sport. There's a noticeable gap on the bottom if you don't install these. I wasn't going to install them myself as messing with the templates was a pain, but when I was done with installing the bumper and noticed the gap, my OCD just wouldn't let it go ... had to do them. It took all of 5 minutes though, and I didn't use the templates, just snugged the plastic fillers up to the bumper edge and drilled the four or five holes through the filler. Easy.
Old Jan 25, 2012 | 09:31 AM
  #1080
BooSa37's Avatar
BooSa37
Explain this further? Can this be installed with the bumper already mounted? A pic of the final product will help. Thanks
