Help Parking lights not coming on
Old Oct 5, 2009 | 08:32 PM
arbelaezr's Avatar
arbelaezr
all lights turn on except parking lights. Taillights, license plate , turn signal, headlights, foglights, interior lights all functioning except parking lights. Any ideas? Is there a fuse? Should i disconnect battery to reset anything?
Old Oct 5, 2009 | 09:12 PM
ucla bruin's Avatar
ucla bruin
Maybe the bulbs are dead. Just a guess. Might be worth checking.
__________________
Old Oct 5, 2009 | 09:49 PM
Check the fuse first. Are the parking light not coming on or the fog lights? Because fog lights do not come on with high beams.
Old Oct 5, 2009 | 11:06 PM
Weiboy718's Avatar
Weiboy718
there's a fuse box next to your battery housing. you gotta undo a few clips and pull the panel out and you'll see the rectangle fuse box. look for your parking light fuse and see if it's burn out. best to test it with a test light
Old Oct 6, 2009 | 11:30 AM
arbelaezr's Avatar
arbelaezr
the foglights work fine... Its just the parking lights.... I checked the rectangular fuse box by the battery, but I saw no fuse for parking light , am I checking the wrong fuse box? ... I havent checked the actual bulbs , I doubt that both bulbs would die at the sametime but I'll double check in a few hours when I get home.
Old Oct 6, 2009 | 02:08 PM
ucla bruin's Avatar
ucla bruin
Dealership.
__________________
Old Oct 6, 2009 | 03:32 PM
SkyMG37x's Avatar
SkyMG37x
The front parking lamps are controlled by one fuse that's separated from the rear lamps so this sounds like your problem. It's Fuse 52 in the IPDM E/R module located next to the battery between the battery and the passenger fender. You need to unclip it from the body to pull it up and remove the cover. Once removed, locate Fuse 52 and verify that it's blown. Here's the IPDM E/R diagram. The red circle was for a different issue and highlights Fuse 53. The fuse just above that one should be Fuse 52.
Now the question is why did it blow? If you were doing any work on that circuit you likely shorted it. Otherwise if you didn't touch anything near the front headlight harness you may need to have it looked at by the dealer to find out why the fuse blew and will likely blow again.
Old Oct 6, 2009 | 09:25 PM
arbelaezr's Avatar
arbelaezr
My parking lights work now! Much thanks to skymg37x ... U were on point , it was the #52 blown fuse...thanks to u all also for ur ideas.... I have aftermarket hid fogs on the bumper tapped into the parking lights.. Dont know wat cause the fuse the blow since I had da hid fogs for 8 months already.. Without a problem. But happy there working again.. Thanks!
Old Oct 7, 2009 | 09:50 AM
SkyMG37x's Avatar
SkyMG37x
Great. If it blows again you'll likely need to take a look at the HID Fogs and whether the tap into the parking lamp circuit has a problem like a bare contact or maybe the HID relay is the problem.
Old May 30, 2014 | 06:22 PM
ANMVQ's Avatar
ANMVQ
I know this is old but I was just trying to hook up my drls the markers
lights went out and this fuse was good , any where else, all other lights work find just
the two markers above the HIDS ?
Old May 30, 2014 | 06:49 PM
ANMVQ's Avatar
ANMVQ
And all the fuses work just checked them all
Old May 31, 2014 | 10:31 AM
ANMVQ's Avatar
ANMVQ
Found the IMPD box ? Didn't know there was another fuse box in the fender .
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
MJ HINX
Aug 23, 2015 10:30 PM
ghostrer
Aug 22, 2015 01:49 PM
