iPhone connectivity issues
Old Jan 22, 2018 | 09:35 AM
  #91
JSolo's Avatar
JSolo
Just say no!!!!!
Were you able to just flash the applications disk (disk 0) without having to flash the map data?
Old Jan 22, 2018 | 01:30 PM
  #92
codeflux's Avatar
codeflux
20 Year Member
Yes, disk 0 (program boot/data) is a stand-alone disk, and can be installed without installing new maps. That's also the disk that doesn't ask for activation code - disk 1 (first maps disk) does that.
So, theoretically, you could try to install it from a copy of someone's disk 0, but honestly, the risk exists that you'll brick your navi if you use a copy, there's no telling what copy protections exists on that disk. Buyer beware.
Now, the results:
Usually slower drive to work too me 22 minutes today, and bluetooth didn't disconnect once. It used to do it at 10 minute or 20 minute mark. My drive back will likely be much longer, so I'll test it again. I also noticed that the phone connected to the car (or, rather, the car to the phone) much faster this time. Track information (I was listening to a long podcast) was blank - but the playback timer was running (when viewed in bluetooth audio screen - but not on the status line when viewing the map).
Again, I'll update tonight after I've driven back home. I can certainly live without track information (who cares, right?), as long as the thing doesn't disconnect me every 10 minutes.
Old Jan 22, 2018 | 03:25 PM
  #93
sev1980's Avatar
sev1980
that's encouraging! waiting for my dvd to come too.
Old Jan 22, 2018 | 04:07 PM
  #94
mdigiorgio35's Avatar
mdigiorgio35
Now, the results:
so my question is does it connect automatically when receiving a call? that seems to be my biggest issue is when i click "answer" i cant hear the person unless i click "phone" then "car" when on the audio settings.
Old Jan 22, 2018 | 04:08 PM
  #95
sev1980's Avatar
sev1980
also wonder if it takes care of the clicking/popping noises i hear
Old Jan 22, 2018 | 05:12 PM
  #96
Cwickenstein's Avatar
Cwickenstein
Originally Posted by jacket18
If you'd be willing to share, that'd be awesome!
I Second that!
Old Jan 22, 2018 | 05:21 PM
  #97
Cwickenstein
Lightbulb
Now, the results:
Thank you so much CODEFLUX for your trial run for all of us! If this works, I'm driving to SF this weekend and will split the cost of the DVD with you and install!!!!
Standing by for your drive home assessment...
Old Jan 22, 2018 | 05:41 PM
  #98
JSolo's Avatar
JSolo
Just say no!!!!!
Are the dvd's they send 'burned' or pressed? If it looks like a store bought dvd movie then that's a standard image burned to thousands of disks. If burned, then the data could definitely be unique to the vehicle/vin.
Old Jan 22, 2018 | 06:13 PM
  #99
Cwickenstein
I think I follow you here. I believe Infiniti asks for the unique head unit ID prior to ordering, so they may very well be vehicle specific in order to keep folks like us from trading out and installing without paying them. Greed-based Capitalism really screws the end user, even when a malfunction warrants a fix...
Old Jan 22, 2018 | 07:10 PM
  #100
sev1980's Avatar
sev1980
About to perform the upgrade on my car as well. Will keep you posted.
If you guys are talking about splitting the cost of DVD's, count me in. I also purchased the map set to try this out I did alot of the research to figure out the map update pack would fix this issue.
I'm happy to share the disc 0 dvd.
Old Jan 22, 2018 | 07:13 PM
  #101
sev1980's Avatar
sev1980
I mentioned this before. the discs are not unique to your car. The nav processes the unlock code and allows the upgrade the proceed.
Old Jan 22, 2018 | 07:24 PM
  #102
Cwickenstein
Right on! Where are you located?
Old Jan 22, 2018 | 09:09 PM
  #103
sev1980's Avatar
sev1980
I’m in Los Angeles.
Man I just went to do the upgrade and totally forgot to turn off Bluetooth before starting the update. Biting my nails it doesn’t screw anything up.
Old Jan 22, 2018 | 09:27 PM
  #104
JSolo's Avatar
JSolo
Just say no!!!!!
Can either of you post a good picture of the non label side of disk 0?
Old Jan 22, 2018 | 11:17 PM
  #105
sev1980's Avatar
sev1980
It’s just a run of the mill stamped dvd
