Help Holistic Solution for iPhone 5
Old Jun 28, 2014 | 07:19 PM
bwc's Avatar
bwc
Hello All,
Curious if anyone has experience with these products or feedback on whether or not this configuration will be a success.
iPhone 5S
Lightning to 30-pin Adapter (0.2 m) - Apple Store (U.S.)
dockStubz: Keep Your Case On While You Dock <--- Micro USB cable to 12V socket adapter
2008 Infiniti iPod Harness
Thanks!
Old Jun 30, 2014 | 10:15 AM
Envee's Avatar
Envee
No, I don't believe the setup you listed will work. The adapter you linked to is female lightning to male lightning. You need a female 30-pin to male 30-pin adapter so you may connect the infiniti ipod harness to it.
I currently run this setup for my iPhone 5; it allows my phone to simultaneously charge while plugged in. It should also work with your 5S.
iPhone 5
Scosche Charging Adapter Scosche Charging Adapter
Old Jun 30, 2014 | 02:17 PM
bwc's Avatar
bwc
Thanks for the suggestion! The adapter I linked also comes in a 30-pin flavor, selectable on the page.
The reason I am looking at this specific adapter, with the external power injection, is because I had multiple adapters similar to the one you linked and one day they stopped supplying power to my iPhone 4. I tried swapping phones and harness cables and determined that it is definitely a problem with my car not supplying the power through the iPod interface. Has anyone else experienced that?
Old Jun 30, 2014 | 06:32 PM
JakeG37's Avatar
JakeG37
iPhone 5
I can confirm this works great for me in my 2008 G37 with bose/navi.
Old Jul 7, 2014 | 04:49 AM
Jokelberry's Avatar
Jokelberry
Newbie question. But is the ipod/iPhone hookup supposed to charge your phone as well as play music? Mine only works for the music portion and doesn't charge. I have an iPhone 5 with the 30 pin to lightning adapter from apple From what I am reading here it seems it should charge my phone as well.
Old Jul 11, 2014 | 02:54 AM
RA081224's Avatar
RA081224
The iPhone requires specific signaling resistors built into the connectors that handshake with the device confirming that an "appropriate" charging device is connected. Just making sure power is supplied to the proper pins on the connector isn't enough. The charging adapter takes care of this detail.
Old Jul 30, 2014 | 04:19 PM
bwc's Avatar
bwc
Got the charging adapter in the mail, everything works perfectly with this combo. I have a 3A 12V-USB adapter and the phone charges very quickly.
Old Jul 31, 2014 | 02:10 PM
R1guy's Avatar
R1guy
I tried using a charging adapter and got lots of feedback while it's plugged in. Scosche sent me a brand new one and same issue...anyone have this problem and can I fix it?
delfinparis
Oct 8, 2015 06:06 PM
butwhatuptho
Oct 4, 2015 07:51 PM
Awgd8
Sep 30, 2015 06:22 PM
sharmelan
Sep 23, 2015 11:48 AM
steven92
Sep 23, 2015 08:48 AM
