I need audio help
Old Jan 30, 2013 | 11:17 PM
brianpatsy's Avatar
brianpatsy
I need audio help
I replaced door speakers in my 2010 G37 coupe with 6.5 components. I installed a 2 channel amplifier to drive these. I tapped into the bose amp wires(33,34,35,36). I spliced RCA's onto these pre-amp wires. This creates noice but no music. If I unplug the RCA's from the amp and plug an i-pod directly into my amplifier then the music plays just fine. This tells me that the amp is hooked up properly. I have the Bose amps completely removed. Do the Bose amps have to remain hooked up to the car. Any help would be appreciated.
Old Jan 31, 2013 | 06:40 AM
Rad_Slinger's Avatar
Rad_Slinger
I don't think yu can direct splice RCAs into the factory harness. I think that's where you're having your issue. You need something like below....
Line Output Converters at Crutchfield.com
Any kind of these will solve your problem.
Old Jan 31, 2013 | 10:19 AM
brianpatsy's Avatar
brianpatsy
Thank you for your input. I have one of those in my garage. I will try it tonight. I didn't use it because I read on here that people were having success just splicing RCA's onto the HU Pre amp wires. I have an old school Kicker ZR 360 amp if that makes a difference. I read on here that our cars put out balanced lines. maybe this amp doesn't accept that type of signal?
Old Feb 2, 2013 | 04:32 PM
brianpatsy's Avatar
brianpatsy
The line output converter did not work. It did however stop the noise. Still no music. How do I convert the balanced signal to unbalanced? Will a Rocford Fosgate 3 sixty line driver do the trick? Do I need to use pin #21(shield)?
delfinparis
Oct 8, 2015 06:06 PM
parkern
Oct 1, 2015 10:15 PM
guitarman1960
Sep 25, 2015 11:50 AM
Murkr
Sep 23, 2015 04:52 PM
steven92
Sep 23, 2015 08:48 AM
