Bose Audio Wiring Breakdown
Old Mar 25, 2015 | 04:47 PM
  #46
dfresh.'s Avatar
dfresh.
Mulitple Amps From Pre-Amps
Probably the only one that on here that owns a Q40 but getting ready to do an audio overhaul. From what I am reading most of you are splicing into the pre-amp wires before they hit Bose amp to send audio signal to their aftermarket amp:
(23) Rear Left - (SB)(Sky Blue) **Preamp from HU
(24) Rear Left + (V)(Violet) **Preamp from HU
(25) Rear Right - (Y)(Yellow) **Preamp from HU
(26) Rear Right + (BR)(Brown) **Preamp from HU
With that mind set, we are saying that those wires are pushing enough signal to power both the new aftermarket amp and the Stock Bose amp?
Additionally, say I were to bypass and remove the Bose amp altogether. Would those pre-amp signals spliced be able to provide for two aftermarket amps?
Thanks for any help,
Old Mar 25, 2015 | 07:39 PM
  #47
Cr0tchf4i's Avatar
Cr0tchf4i
It's a component setup, so I believe you would have to replace all of the speakers as well. The stock amp will provide you with enough power/signal, barring you are not using a fosgate amp which takes a bit more power to trigger on.
Old Mar 26, 2015 | 01:51 PM
  #48
dfresh.'s Avatar
dfresh.
Thanks for the info. Yes replacing the speakers is part of this process as well. Nothing against Bose normally, but just not cutting it in this car.
Old Mar 29, 2015 | 10:05 AM
  #49
cristinaharn's Avatar
cristinaharn
I would like to thank you for the efforts you have made in writing this post. I am hoping the same best work from you in the future as well. In fact your creative writing abilities has inspired me to start my own blog now.
_____________
affiliate marketing
Old Apr 16, 2015 | 10:39 PM
  #50
mmnjtwa's Avatar
mmnjtwa
Originally Posted by Tennessee
I'm trying to find the passenger side wires for the Right Front woofer in the passenger side kick panel and I am having no luck. These wires (output from the bose amp, are Green (+) and Red (-). I see the Driver side woofer wires Black(+) and White (-), in the driver side kick, but I also see Red and Green in that same bundle on the driver's side. Does anyone know if these wires travel under the dash, all the way across to the passenger side Molex?
I have the same problem ... Has anyone figured out this yet?
https://www.myg37.com/forums/audio-v...-footwell.html
Old Apr 26, 2015 | 09:33 PM
  #51
Eddie1218's Avatar
Eddie1218
Getting everything together to install amp/sub. Haven't got eyes on the bose amp yet. I need to know what gauge are the wires coming out the bose amp so I can order the right taps. Any help will be much appreciated?
Old May 4, 2015 | 02:27 AM
  #52
mmnjtwa's Avatar
mmnjtwa
The wire sizes range from around 20-22, 16-18, and some closer to 12-14, if I recall correctly. You'll want to pick up a few of each size.
Old May 9, 2015 | 03:40 AM
  #53
cristinaharn
I enjoy it. everyone visits and shares information
________________
Affiliate Lead App - Sign Up Free
Old May 31, 2015 | 02:06 PM
  #54
socketz67's Avatar
socketz67
Community Builder
Found this buried in another thread from 2011. The color coding is helpful.
Thought it made sense to add to this thread:
Old May 31, 2015 | 03:01 PM
  #55
CRiME's Avatar
CRiME
Can you provide an enlarged version of that by any chance? It is a thumbnail size even after clicking on it. kind of looks like an 80's TV screen after a station went "off the air"
Old May 31, 2015 | 04:46 PM
  #56
socketz67's Avatar
socketz67
Community Builder
Looks like I grabbed the URL of the thumbnail image the first time. Fixed.
Old Jun 25, 2015 | 06:07 PM
  #57
l50k's Avatar
l50k
I been trying to find this info
Old Jun 26, 2015 | 08:35 PM
  #58
socketz67's Avatar
socketz67
Community Builder
This thread rocks. Shame that there is not more activity in the audio forum. Adding a sub to the factory Bose system is one of the first modifications you should make to the car.
Old Oct 24, 2015 | 05:40 AM
  #59
JakeG37's Avatar
JakeG37
Ok guys, I have been double checking my wiring for a stereo install and I cant seem to clear up a couple of things. I have a coupe with Navi and my system is:
Tweeters (front L/R) B41 35&36/ 33&34? (preamp from HU)
Mid Bass (front L/R) B41 23&24 / 25&26? (preamp from HU)
10" sub in the trunk - is there a Preamp from HU for sub?
Also, when I add my mids making it a 3-way component system, where would I get HU preamps for those? I will be adding a second amp since I am running a fully active crossover setup.
Its really late and Im exhausted so I apologize if I am not making any sense.
Old Nov 9, 2015 | 01:02 PM
  #60
chickman1313's Avatar
chickman1313
just got my G and will be the first mod I do I believe. from reading through the thread I found where I need to attach my amp and sub (I think) to the stock bose equipment.
any recommendations on subs and/or amps to go with? Been out of the car audio game about 10 - 15 years, not looking for as much bump as I once was, but I just feel like the stock system isnt cutting it for me. Was thinking a 12 would do the trick, hell maybe even a 10.
Isnt there a stock sub in the bose system?
