Bose Audio Wiring Breakdown
Old Mar 26, 2010 | 11:13 AM
vactor's Avatar
vactor
is there a definitive list of what the speaker sizes are in the g37 sedan? nobody seems to know and crutchfield is not on their game when it comes to the G37 ...
Old Jun 5, 2010 | 10:11 PM
use2vw's Avatar
use2vw
anyone have a detailed lay out of the g37 sedan wiring? Or even better, what wire colors are needed for Right Rear +/- and Left rear +/-. Also what wire to tap for amp REMOTE? *Sorry if this is covered elsewhere..I'm at this thread
Old Aug 15, 2010 | 11:34 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
Good Info
Old Dec 24, 2010 | 08:57 PM
vactor's Avatar
vactor
Originally Posted by ironchef2008
Here's a wiring breakdown for the Bose amp and Woofer amp. Please note that wiring color may not be the same at the speakers. These are for at the amp only and the pin number reflects the harness seen from where the wires go in, not the terminal side.
Bose Amp
Harness B42 (Pin Number/Item/Color Code)
(1) Front Left Mid/Tweeter + (L)(Blue)
(2) Front Left Mid/Tweeter - (W)(White)
(3) Front Right Mid/Tweeter - (LG)(Light Green)
(4) Front Right Mid/Tweeter + (V)(Violet)
(5) Front Right Woofer + (G)(Green)
(6) Front Right Woofer - (R)(Red)
(9) Front Left Woofer - (W)(White)
(14) Front Left Woofer + (B)(Black)
(10) Power/Key (Y)(Yellow)
(11) Power/Constant (GR)(Grey)
(12) Ground (B)(Black)
Harness B41 (Pin Number/Item/Color Code)
(16) Rear Woofer + (SB)(Sky Blue) **Signal to woofer amp
(17) Rear Woofer - (V)(Violet) **Signal to woofer amp
(18) Rear Left Mid + (L)(Blue)
(19) Rear Left Mid - (P)(Pink)
(23) Rear Left - (SB)(Sky Blue) **Preamp from HU
(24) Rear Left + (V)(Violet) **Preamp from HU
(25) Rear Right - (Y)(Yellow) **Preamp from HU
(26) Rear Right + (BR)(Brown) **Preamp from HU
(29) Center + (L)(Blue)
(30) Center - (O)(Orange)
(31) Rear Right Mid + (LG)(Light Green)
(32) Rear Right Mid - (Y)(Yellow)
(33) Front Right + (R)(Red) **Preamp from HU
(34) Front Right - (G)(Green) **Preamp from HU
(35) Front Left + (P)(Pink) **Preamp from HU
(36) Front Left - (L)(Blue) **Preamp from HU
(20) Power/Amp On (W)(White)
Woofer Amp
if i want to use the front and rear outputs from the radio before the amp, i connect my amp to these pins on connector B41 / B42, correct?
in other words, there is a balanced (+ and-) coming from the headunit / nav unit that exits at the connector to the amplifier at the above pins, right?
then, if i want to use the stock wiring to connect the outputs from my new amp to the factory speaker harness, i use these:?
is that correct?
thanks much! i am setting up a rather high powered and advanced system using the factory locations (other than the sub, as i will be using 2 12" subs in a small box) and a JBl MS-8 processor. i do not want to cut any wires and want to keep the install as stealth and reversible as possible ...
p.s.
which is the remote turn on lead? this
or this
thanks again!!! pics and log to come!!
Old Dec 27, 2010 | 12:10 PM
Viper62382's Avatar
Viper62382
Where are the BOSE amps located?
Old Dec 27, 2010 | 12:15 PM
RaulGCustom
SoCal Driven
In the trunk
Old Dec 27, 2010 | 02:12 PM
Tuckermaclain's Avatar
Tuckermaclain
In the sedan the rear speaker is 11". You can use a 10" without too much trouble bit a 12" would require some cutting. That would be LOTS of work.
Old Dec 28, 2010 | 06:16 AM
1NEETO's Avatar
1NEETO
Ok I did try to search but found nothing. What's the power rating of the 11 speaker system? What's the power rating of each amp?
Old May 16, 2011 | 04:26 AM
ShyAznB8oi's Avatar
ShyAznB8oi
what is the b41, b42, and b43 meanings?
thanks
Old Dec 13, 2011 | 04:37 PM
apexi350z's Avatar
apexi350z
thanks
connector number label on the actual wire diagram from Infiniti Service Manual.
Old Dec 14, 2011 | 10:17 AM
rickd69's Avatar
rickd69
Has any body answered this.....I am looking for the power capacity (in amps) of the power wire to these stock amps (bose amp or Woofer amp), is there a dedicated fuse for each??
Old Jan 1, 2012 | 03:50 PM
Tennessee's Avatar
Tennessee
I'm trying to find the passenger side wires for the Right Front woofer in the passenger side kick panel and I am having no luck. These wires (output from the bose amp, are Green (+) and Red (-). I see the Driver side woofer wires Black(+) and White (-), in the driver side kick, but I also see Red and Green in that same bundle on the driver's side. Does anyone know if these wires travel under the dash, all the way across to the passenger side Molex?
Old Aug 29, 2012 | 08:47 PM
kash829's Avatar
kash829
thanks for the information!
Old Dec 27, 2012 | 08:57 PM
  #29
Gwhizz's Avatar
Gwhizz
Are there any crossovers in the doors or rear. My question is, if I change my front and rear speakers, will I have any issues using the factory wiring?
Thanks
Tom
Old Jan 28, 2013 | 10:37 PM
  #30
dillyyo's Avatar
dillyyo
If you are running a serious aftermarket amp set up, you will need to run higher gauge power distribution.
