Hidden Radar Detector on G37?
Thanks.
It has a port for a usb cable that is accessible under the dash (laptop is the key, or a pc in the garage...). The database is updated fairly often. It has speed cameras and red light cameras and warns you ahead of them (warning time depends on how fast you are going).
Dean
The display is actually in the instrument cluster so there's no reaching that.
Heres the link:Controller Picture
I asked for a lot of input and got some good help:
http://g35driver.com/forums/showthre...ghlight=9500ci
The control is seperate and is mounted just above the ash try. It is visible in another picture. All of the buttons are easily reached. I drive with my hand on the shift **** (even though it's an auto) and it is within reach without moving my hand from its resting place.
Dean
Here are a couple of pics of my Passport SRX install. The radar sensor is mounted dead center behind the honeycomb grill(sorry for the bluriness, took these at night).
Mounted the stealth led under the hood for the screen. It stays green when nothings around, then flashes red(variable depending on strength) when it senses radar or laser.
The control unit mounted in the top of the glove box.
Just a few side notes. Theres a mute button mounted inside the ashtray, there is a speaker mounted and hidden under the glove box, and I haven't mounted the front and rear laser diffusers yet as I have to order a new front grill to cut in the units as they would look like *** otherwise. The performance of this one is above the 8500/9500i. It is above a grand for the unit and the install won't be cheep, but its worth it if you want the clean looks and great performance.
Dean
That may not be the best idea as the x50 is not waterproof. In order for it to "see", the sensors have to have the least obstructions as possable.
I will let you know once I find out the exact details. I never thought about it not being waterproof. I will run his suggestion by you guys first if you dont mind once I talk to him in person.
Dean
9500ci has worked flawlessly. Price..... notso hotso.
Here's my install:
Here's my install:
