wiring diagram?
Old Feb 10, 2008 | 04:06 PM
gomezg37's Avatar
gomezg37
wiring diagram?
hey i was wondering if anyone has the wiring diagram.
Old Feb 10, 2008 | 04:52 PM
Dieseldoug22's Avatar
Dieseldoug22
I have the a copy of the service manual. What wiring diagram were you looking for. It is really broken down into specific pieces.
Old Feb 11, 2008 | 11:43 AM
gomezg37's Avatar
gomezg37
i was looking for the radio unit.
Old Feb 11, 2008 | 02:35 PM
Dieseldoug22
Do you want to know where all the wires connect to, or what wires are in the connectors? Do you want to know the AV Control Unit, Bose Amp, or Sub Amp? If you tell me what you want to do I can send you the appropriate pages.
Old Feb 11, 2008 | 03:12 PM
gomezg37's Avatar
gomezg37
yeah i wanted to know what the wires connect to and what each wire stands for. I was also wondering if you have the page that says where the IAT sensor or MAT sensor is located in the engine. it should be around the throttle body or around the air intake. thanks alot
Old Feb 11, 2008 | 03:44 PM
Dieseldoug22
If you PM me your email I can send you the whole AV section of the Service Manual. It will tell you all you need to know about the radio.
The IAT is built into the mass air flow sensor. According to the manual.
Old Feb 11, 2008 | 03:46 PM
Dieseldoug22
Heres the page with the IAT sensor
File Type: pdf
Old Feb 11, 2008 | 03:51 PM
gomezg37's Avatar
gomezg37
PM sent.. thanks for all the help bro.. really appriciate it..
Old Feb 23, 2008 | 04:45 PM
Sirhc7897's Avatar
Sirhc7897
If you wouldn't mind I'd love to know which wires down around the fuse box (driver side kick panel) are key on power....
Would like to run my V1 cable down there to finish hiding all the wiring but life would be much simpler if I knew which wires were key on power to splice it in...
Old Feb 23, 2008 | 05:52 PM
Dieseldoug22
Check out the pic I added and top left of the diagram. The connector labeled "M1" is the one that you want to use. It is associated with fuse number 20 and is connected to the "Power Socket". Find the wire "6A" which is I believe a yellow wire.
Now just remember to use a 12v light meter or a volt meter to double check that the power goes on and off with the ACC function of the start button. Once you double check that the harness does what you want it to do it should work fine.
I am solely going off of the service manual so I have not physically seen the harness. And of course when you make your connection pull the fuse at least, if you don't disconnect the battery.
And of course this is only informational purposes only and you assume all risks with performing this service.
File Type: pdf
Old Apr 20, 2008 | 06:06 PM
g37vanbc's Avatar
g37vanbc
I was wondering if anyone has a wiring diagram for the courtesy lights. i am installing a set of puddle lights under the car and i am trying to find a source for the power.
37
Oct 17, 2020 11:12 AM
Rybitron
Nov 18, 2015 03:11 PM
dedmanchan
Sep 24, 2015 11:25 PM
SheLLz
Sep 24, 2015 08:02 PM
RexHavoc
Sep 6, 2015 01:03 AM
