Need help with tires, again
So time to replace the front tires, but might have to replace all four. On the front, one has a hole in the sidewall, and the other has a bubble starting in the sidewall. My current tire size on the front are 235/35/20, and the rear are 285/35/20. I want a front tire with more meat to it, but I also do not want to trip the abs sensor again. What size would yall recomend? Wheel size on the fronts are 8.5 +35 while the rears are 10" +38.
Also when it is time to replace the rears, I will most likely stick with the BFG sport comp 2, but will have to downsize the width to 275 due to rubbing on the bumper to fender bracket.
Is it possible to have a front tire work with both a 285 and a 275 rear width setup? I assume yes, but I might have to change the rear sidewall height?
Thank you!
Thank you!
Thank you!
Thank you!
Am I able to run 245/35 on the front with my current tire set up AND a 285/30, or is it one rear size or the other?
VelisG37s
Nov 7, 2015 12:41 AM
