Help Running 295's
Old Jun 10, 2013 | 09:09 AM
Sunny G's Avatar
Sunny G
I would not recommend running 295s with a low offset like +23 as there will be rubbing on the fender liner and the fender bolt. Also you have to be dropped quite a bit for them not to stick out in the first place. There are members running this setup however they have other things going on that helps them in fitting a wide tire. e.g camber below -3 degrees, coils, shaved fender bolt, fender pull etc...
Old Jun 10, 2013 | 10:06 AM
SgtGoldy's Avatar
SgtGoldy
thats a lot going on. I have a full camber Front and Rear. I guess I might have to shave. but pulling is a bit too much for me...
Old Jun 10, 2013 | 11:55 AM
Seraphix's Avatar
Seraphix
Like sunny said you can make it fit. But if your buying high quality expensive tires you probably wouldn't want to run that set up, your going to have to run significant camber to make it fit dude.
Old Jun 10, 2013 | 06:51 PM
SgtGoldy's Avatar
SgtGoldy
Yea I'm rocking some pzero corsas (about 600 a tire... ). Dang maybe I'll go witha smaller tie and poke a little?
Old Jun 10, 2013 | 06:59 PM
Seraphix's Avatar
Seraphix
You'l be good with a 265/30 at factory camber and toe specs or close to it, and you can still be slammed. All u have to do is shave the bumper bracket and trim the liner. I had my gt30's at +22 with that exact set up.
Old Jun 10, 2013 | 07:10 PM
SgtGoldy's Avatar
SgtGoldy
cool man, thanks for the heads up. I'll probably look into doing that then.
Old Jun 10, 2013 | 10:14 PM
Good luck, post pics when you get it set up.
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
delfinparis
Nov 16, 2015 02:26 PM
bobtaz13
Oct 1, 2015 01:39 PM
