Official~Best offsets for running FAT tires!
Old Apr 14, 2014 | 08:03 PM
  #736
Originally Posted by inknartg37
Quick Question. Finally getting coils put on this Friday.
Setup is 20x9 30 Front W/ 245/35/20 Hankook K110 V12 with 20x10.5 40 Rear with 285/30/20 Hankook k110 v12
I'm running 15mm spacers all around. Fronts look good, the back poke out a little, am I going to be able to clear the fender when I go lower? I've already shaved the brackets as i'm on eibachs and with the spacers I started to hit.
I assume you've got the coupe. Should tuck in about 5mm from an Eibach drop down to zero-gap w/ coils. At least you're in a good place since you can always remove the spacers and get a thinner one if needed, a lot better than being stuck w/ a poked setup and only help you can get is with camber or new wheels
Old Apr 14, 2014 | 09:05 PM
  #737
inknartg37's Avatar
inknartg37
Good point! Could always go down to 12 or 10, i'm hoping the tuck perfectly when I get them flush.
Old Apr 17, 2014 | 02:04 AM
  #738
kdawg8526's Avatar
kdawg8526
Look forward to pics, what are you dropped on BTW?
on eibach srings
Old Apr 23, 2014 | 01:01 AM
  #739
kdawg8526's Avatar
kdawg8526
heres some quick pics with the 19x10+30 275's in the rear and the front is 19x9+47 245's
Old Apr 23, 2014 | 08:38 AM
  #740
Way to go Dawg! Those look & fit great!
Old Apr 23, 2014 | 12:48 PM
  #741
kdawg8526's Avatar
kdawg8526
i do have rubbing issues when going into driveways the rear rubs i may have to camber it a lil in
Old Apr 23, 2014 | 02:16 PM
  #742
If it's just rubbing on that felt fender liner I wouldn't worry about that, or you can cut it back if it bugs you. If it's hitting metal then that would be a concern.
Old Apr 23, 2014 | 07:15 PM
  #743
kdawg8526's Avatar
kdawg8526
dont lnow where its rubbing but seems like the metal because the wheels do stick out a lil past the fender
Old Apr 23, 2014 | 09:56 PM
  #744
MiPwnYew's Avatar
MiPwnYew
Would running a 20x9 +35 in the front with a 15mm spacer and 245/35/20 tires on the sedan be doable without any rolling/ridiculous camber?
Old Apr 24, 2014 | 09:37 AM
  #745
Should be fine without a spacer IMO. Should be pretty flush but still have room to clear the non-rolled front fender.
Old Apr 24, 2014 | 10:08 AM
  #746
ttv36's Avatar
ttv36
Race, repair, repeat.
Some daytime pics 245/40/19x10 +25f and 295/30/19 +30r
Old Apr 24, 2014 | 10:17 AM
  #747
Very nice Tony, that view from the front is just mean!
Old Apr 24, 2014 | 11:42 AM
  #748
kdawg8526's Avatar
kdawg8526
295's thats awesome
Old Apr 26, 2014 | 02:27 PM
  #749
quakerroatmeal's Avatar
quakerroatmeal
The OEM Coupe 19's you had before > the new 370z wheels imo
Old Apr 27, 2014 | 08:07 PM
  #750
pmartell12's Avatar
pmartell12
2010 g37 x with 20x9+32 front 20x 10.5+45 rear... 245 and 285 respectively. also the first white g37 with vossen cvt's posted online!Name:  DSCF2258.jpg
Size:  76.3 KBName:  DSCF2260.jpg
Size:  63.2 KBName:  20140427_162143_HDR.jpg
[IMG]https://www.myg37.com/forums/<a href=http://s1180.photobucket.com/user/pmartell12/media/DSCF2258.jpg.html target=_blank>Name:  DSCF2258.jpg
