Official~Best offsets for running FAT tires!
Old Jul 19, 2013 | 05:29 AM
  #451
vinceva's Avatar
vinceva
And obese brakes
Killer setup!
Originally Posted by TheGanglyGoon
UGHHHH FACKKKK you have my favorite sedan. hands down
Originally Posted by kdawg8526
damn looks real good what are the wheel/tire specs
Thanks guys, appreciated!
Wheel spec: 19/8.5/38; 19/10.5/35
Tires: 245/40/19 275/35/19, the golden size that blnewt mention.
however, I gonna switch to 265/35, can't take any kind of chick right now with 275, u know what i mean
Old Jul 19, 2013 | 07:11 AM
  #452
Robert_K's Avatar
Robert_K
Boo! You'll be leaving this thread with a 265/35 on those rears. Need a 285!
Old Jul 19, 2013 | 06:31 PM
  #453
Skyline6mt's Avatar
Skyline6mt
On 10.5 inch rears you should be running 285 or more....unless you wanna move over the the stances thread
Old Jul 21, 2013 | 03:02 AM
  #454
JRW370's Avatar
JRW370
Question
Originally Posted by Skyline6mt
Thought I'd throw this in here....uhhh i think its time for tires again...what do you guys think
Time for some MEAT!
I used to have the same thing happen on my Bimmer 545, but it had a real aggressive negative camber set up on the rear wheels. It also ate rear tires for breakfast.
Just curious...is this common with running fat tires and offsets on the G or is your car lowered as well?
Old Jul 21, 2013 | 03:28 AM
  #455
Robert_K's Avatar
Robert_K
Hey guys!!!! Updated the first post with some interesting videos I found via Forgeline's YouTube page. They discuss center locks. Check them out and let me know what you think!
With a proper alignment you shouldn't see this happening. This is a prime example of what your patch contact is with a crazy camber. Improper toe could assist on this as well.
I run really aggressive tire fitment on my 350Z but have a "square" alignment for maximum tire/road contact.
Old Jul 21, 2013 | 11:43 AM
  #456
Skyline6mt's Avatar
Skyline6mt
^ I wouldn't say its common. Like Robert said if your within factory spec you shouldn't have an issue. I'm not running crazy camber or anything just eibachs with no camber correction. On the canyons it feels better to have the extra cornering grip. Toe, caster, etc. are all within spec.
A square setup is great but the mid corner grip is much better with a little more front camber. The rear you see here is actually within factory spec on one side and just over factory on the other side. What you see was the result of a lot of sliding one day an an uneven and abrasive surface. The hankooks don't seem to like abuse too much hahaa
Old Jul 21, 2013 | 12:06 PM
  #457
Robert_K's Avatar
Robert_K
Yeap. And my Z is built around running high-speed on long straights and for the Texas Mile. (If I ever get home for it.)
The Infiniti is set for OEM alignment specs.
Old Jul 21, 2013 | 12:28 PM
  #458
Skyline6mt's Avatar
Skyline6mt
It all makes sense now! Haha
All that said I'll probably get a fresh alignment once I get these new tires on, it's been about 15-18k miles now since I did
Old Jul 21, 2013 | 12:30 PM
  #459
Yep, my alignment is well within spec and no wear issues, every bit as good as oem tire wear.
Old Jul 22, 2013 | 01:03 AM
  #460
JRW370's Avatar
JRW370
Thanks guys, that's good to know! I'm hooked on the fat tire look and ready to upsize as soon as the OEM Bridgestone's wear out.
Old Jul 22, 2013 | 01:10 AM
  #461
vwalkerg37's Avatar
vwalkerg37
Sophia got some new shoes....
Here are some images of my new set up.
I am running 245/35/20 up front on a 9.5" wide rim and 275/30/20 on a 10.5 in the rear.
Attached Thumbnails Official~Best offsets for running FAT tires!-sophia-4.jpg   Official~Best offsets for running FAT tires!-img_1777-copy.jpg   Official~Best offsets for running FAT tires!-sophia-6.jpg   Official~Best offsets for running FAT tires!-sophia-3.jpg   Official~Best offsets for running FAT tires!-sophia-10.jpg
Old Jul 22, 2013 | 02:43 AM
  #462
Skyline6mt's Avatar
Skyline6mt
^looks good man but if i had 10.5 rears id be running at least 285-295. Try it our for your next tire change along with a drop and i think you'll love it
Old Jul 22, 2013 | 09:34 AM
  #463
BANNISTER's Avatar
BANNISTER
^^^ agree with the drop .. that brake color looks great
Old Jul 22, 2013 | 10:26 AM
  #464
teekaywhy's Avatar
teekaywhy
Great thread! Too bad I don't have time to read all 31 pages here at work.
I got a great deal off the site for a square Five AD SF5 setup. 265/30/20 +33 ( I think) on 10" rim widths.Now, I'm finding I have a slow leak on one of the tires between the bead and the rim. Took it to a local shop and had them try to clean it up. No dice. Still leaking. It's odd, some days it leaks like a ****...other days it holds pressure.
My option at this point is to replace the tires with something less stretched. I'm thinking 275/30 front and 285/30 rears. No drop on the suspension. I sort of like the "bulldog" look with the wheels sticking out.
Any fitment issues?
Old Jul 22, 2013 | 11:04 AM
  #465
vwalkerg37's Avatar
vwalkerg37
tire size
I think I will...I went with the sizes my tire shop recommended, but I think a little fatter would be sweet.
I am waiting to do the drop till I get my FI CBE so I can see how much I want to do. I am only thinking 1" in rear and maybe 1.5" in front. I do not want any scraping nor do I want to fear driveways or speed bumps. I love the lowered look and performance gains...hate the tire issues and some of the other things it can cause. My friends g is on coil-overs with camber kit...with a staggered set and he eats rears...even though he has it aligned every 6 months (or so he says! )
