Need info on TMPS's
Old Apr 19, 2011 | 09:43 AM
Retromoe's Avatar
Retromoe
Need info on TMPS's
My rear wheel TPMS stem broke off while switching from my winter to summer tires, can i just purchase any infiniti TPMS have it installed at the tire shop? or does it have to be programmed? Due to the fact infiniti is giving me a hard time just to have the damn thing replaced.
Old Apr 19, 2011 | 09:46 AM
Weiboy718's Avatar
Weiboy718
Yes, you can pick up any g37 sensors but will need to be reprogrammed. Also, whoever broked it should replace it for you for free
Old Apr 19, 2011 | 10:32 AM
Fezzik's Avatar
Fezzik
Also need to check what year your car is. If it was made march of 2010 or later it will require the the version of the TPMS sensor and if made before 03/2010 then the older version.
Old Apr 19, 2011 | 10:37 AM
MSCA's Avatar
MSCA
Did you break it or did the tire shop break it? If it was the tire shop, make them pay for the new sensor and associated programming.
Old Apr 19, 2011 | 02:06 PM
Retromoe's Avatar
Retromoe
Well the tire shop tech warned me about it before proceeding to remove the tire, I had a metal/steel type of air valve cover on the stem and he turned it and it broke, basically leaving the valve stem shorter than normal.
Old Apr 19, 2011 | 02:16 PM
MSCA's Avatar
MSCA
Well the tire shop tech warned me about it before proceeding to remove the tire, I had a metal/steel type of air valve cover on the stem and he turned it and it broke, basically leaving the stem shorter than normal.
What, the metal cap was corroded onto the valve stem? He could have put some penetrating oil on it instead of twisting it until it broke. BTW, it takes a good amount of twist to break a valve stem like that. I'd still make an issue of it just because the guy was an idiot. There's no reason to break a valve stem like that, especially when it's part of an expensive sensor.
Old Apr 19, 2011 | 03:02 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Use existing sensors = do not need to reprogram. Buy new sensors = needs to be programmed into the computer via your dealer.
Old Apr 19, 2011 | 03:49 PM
Retromoe's Avatar
Retromoe
Originally Posted by MSCA
What, the metal cap was corroded onto the valve stem? He could have put some penetrating oil on it instead of twisting it until it broke. BTW, it take a good amount of twist to break a valve stem like that. I'd still make an issue of it just because the guy was an idiot. There's no reason to brake a valve stem like that, especially when it's part of an expensive sensor.
Exactly, it was corroded, It's too late now to make a fuss ill probably work something out when he installs it for me.
So your saying i can get a used tpms off any G37 and just install and it should work perfectly right?
Old Apr 19, 2011 | 04:56 PM
MSCA's Avatar
MSCA
No, you'll have to get the sensors programmed to your particular car even if you install used sensors.
37
Oct 17, 2020 11:12 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
BurtoN86
Nov 3, 2015 04:40 PM
BurtoN86
Sep 30, 2015 03:32 AM
VIVID
Sep 27, 2015 09:45 AM
