Official Vossen G37 Wheel Thread! Post Up!
Old Mar 29, 2015 | 06:59 PM
  #2491
FTJ_OX's Avatar
FTJ_OX
Good eye blnewt, the setup was originally front 25.75" and rear: 26.25" but to fit the front tires I had to go up to 26.5" in the front . So I'll probably raise the rear until it's time to switch tires and I run a more narrow tire in the front and drop it.Right now Im at 245/35/20 & 275/30/20.
Old Mar 30, 2015 | 09:24 AM
  #2492
dagon68's Avatar
dagon68
Very nice choice FTJ indeed. Yea those Tein's need to be adjusted but looks awesome!
Old Apr 2, 2015 | 03:44 PM
  #2493
simpson_G37X's Avatar
simpson_G37X
Vossen VFS1 20x10.5 +25, 275/30/20 Hankook V12's. 2010 G37x on eibachs, no rubbing (rear fender liner trimmed)
Size:  392.3 KBName:  IMG_20150327_182655_zpspvbkdelm.jpg
Old Apr 13, 2015 | 12:10 PM
  #2494
09BlkObsSdn's Avatar
09BlkObsSdn
Just installed a set of Vossen Gloss Graphite 20" CVTs.
20x9 +32, 20x10.5 +45 on Hankook V12s with 245/35/20 and 275/30/20.
Old Apr 16, 2015 | 06:44 PM
  #2495
fastlane45's Avatar
fastlane45
Spring is finally here!
Old Apr 24, 2015 | 10:57 PM
  #2496
weedymane's Avatar
weedymane
Wheels dimension recommend for G37 coupe awd pls? I am looking for vfs2 19" will run 245/40/19 275/35/19
Old Aug 5, 2015 | 11:16 AM
  #2497
nhnas38's Avatar
nhnas38
Originally Posted by Furlow
Vossen VFS-1, silver brushed, 20x9 +32 and 20x10.5 +45. 255/35/20 and 285/30/20 Continental DWS tires. Swift springs/Koni shocks.
How many fingers can you fit in your wheel gap? Any rubbing in the front?
Old Sep 20, 2015 | 06:27 AM
  #2498
Spence_moran's Avatar
Spence_moran
Anyone here or anyone you know with vossen 20" and looking to go back to OEM 19" let me know. Still has 75% tread on tires
Thanks guys and happy driving (:
Attached Thumbnails Official Vossen G37 Wheel Thread! Post Up!-20150917_134953.jpg   Official Vossen G37 Wheel Thread! Post Up!-20150919_172008.jpg
Old Sep 20, 2015 | 10:45 AM
  #2499
nhnas38's Avatar
nhnas38
Just to let you know these are the coupes 18 inch wheels. If you take a look at the tire side there is a series of number like this XXX/XX/XX. The last one will tell you the rim diameter.
Old Sep 22, 2015 | 06:21 AM
  #2500
19" Staggered Vossen CVT.
Swift springs and OEM shocks in the front, Tein Basis Coilovers in the rear. 26 3/4" floor to fender all the way around.
Old Sep 24, 2015 | 09:31 PM
  #2501
slartibartfast's Avatar
slartibartfast
This is where someone needs to compile some suspension parameters so wheel frequency can be calculated. I have to wonder how the two ends ride? And how the two sets of dampers work together? I'm not poo-pooing your result, but after living in the Miata world a few years these questions now haunt me.
FatCat Motorsports created a spreadsheet that let you determine wheel frequency using spring rate as a variable for Miatas. It even included the effects of sway bars. Very informative and useful. Since the wheel rates and spring rates are rather different on the G, it's difficult for me to assess ride effect of stiffer springs on the various coil-over offerings. This exercise on FWD w/ MacPherson strut cars is quite easy as the two are almost the same.
Old Nov 3, 2015 | 09:25 PM
  #2502
abretz89's Avatar
abretz89
Picked up a set of CV2 20x9+20 front and 20x10.5+25 rear and put Nitto 555's in 245/35 275/30 on them.
I'll be lowering it next and thinking Eibach springs. Can I go lower than that with my tire setup without running into rubbing issues or would it be safest to stick with Eibach?
Also, I seem to be noticing a slight knocking-like noise and shimmy with these wheels on at lower speeds and when slowing down. Can't pinpoint which corner and can only tell with the windows up, seems normal with windows rolled down. Could it be from not having hubcentric rings? Any tricks to getting them seated perfectly on the hub? Also what is the centerbore of the cv2, I assume the usual 73-66.1 hub rings are what I need?
On to the pics..
Attached Thumbnails Official Vossen G37 Wheel Thread! Post Up!-photo134.jpg   Official Vossen G37 Wheel Thread! Post Up!-photo420.jpg   Official Vossen G37 Wheel Thread! Post Up!-photo158.jpg
Old Nov 16, 2015 | 11:25 AM
  #2503
Almost time to swap the wheels out for Winter, and an opportunity for one last photo shoot before it gets nasty again.
Two years now with VOSSEN 19" CVT. Still loving these rims. Very elegant, very unique. They look almost like they belong on the car as a high-end OEM option.
Old Dec 21, 2015 | 05:19 PM
  #2504
MoonlightWhiteG's Avatar
MoonlightWhiteG
Vossen CVT 20x10.5 all around
Old Feb 16, 2016 | 11:00 PM
  #2505
ScorpionGeo's Avatar
ScorpionGeo
well this thread kind of died =(
