Lease Return Tread Depth
Old Jan 5, 2011 | 08:20 PM
bluesun's Avatar
bluesun
I have to return my G37s Coupe with the optional summer tires at 39,000 miles. Right now I'm at 19,000 and my tires are almost bald. Really not looking forward to putting on a set now, and another right before I return it (or get charged for it after I return it) I can't find where it states what the tread depth needs to be. Does anyone know what this number is or where it can be found? Is it prorated at all?
Also, what do they do about a curb rash on the rim? Thanks for all the help.
Old Jan 5, 2011 | 08:29 PM
Mike's Avatar
Mike
4/32".
Curb rash may be charged for, depending on how bad it is.
Old Jan 5, 2011 | 08:31 PM
Coprolite's Avatar
Coprolite
If it makes you feel any better, the OEM tires are known to be pretty bad on the tread life side. If you choose wisely, you might make it on the next set of tires.
Here's what is available on the Infiniti website:
normal Wear and Use
• Tires with a 1⁄8" tread depth or greater at the minimum-thickness point
Excessive Wear and Use
• Tires with less than a 1⁄8" tread depth at minimum-thickness point
• Tires with sidewall damage (cut,bulges,cracks,etc.)
• Tires with plugged repairs are not allowed
• Any tire not part of a matching set
• Any tire that does not match vehicle’s original tire type, quality, size and rating is not allowed
It only took about 15 second on the InfinitiUSA site to find this:
http://www.infinitiusa.com/content/d...Use_Guide.pdf#
Good luck
Old Jan 5, 2011 | 08:48 PM
bluesun's Avatar
bluesun
Thanks for the link. I couldn't seem to get past the Lease vs. buy section.
Old Jan 5, 2011 | 08:53 PM
Coprolite's Avatar
Coprolite
I am a master jedi manufacturer website navigator.
37
Oct 17, 2020 11:12 AM
indyn
Nov 17, 2015 06:48 PM
Murkr
Sep 28, 2015 10:45 AM
Slapshot1
Sep 27, 2015 08:40 AM
Chris_M
Sep 25, 2015 08:38 PM
