Help 245/45/19 on OEM front rims RUB?
Old Jun 8, 2009 | 12:42 AM
Loi's Avatar
Loi
Will tire size 245/45/19 rub or give any problems for the front oem rims ? I am dropped on Eibachs. thanks
Old Jun 8, 2009 | 11:18 AM
HamstersG's Avatar
HamstersG
Nope. Number of us are running them. No issues.
Old Jun 8, 2009 | 01:03 PM
Loi's Avatar
Loi
cool! thanks!
Old Jun 8, 2009 | 03:08 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Could also use 245/40-19 to give a bit more clearance.
Old Jun 8, 2009 | 03:13 PM
HamstersG's Avatar
HamstersG
OK I have to correct my post.....I missed the "45". Most common set up is 245/40/19, 275/35/19.
Old Jun 8, 2009 | 05:32 PM
G37Sam's Avatar
G37Sam
Believe it or not, you will rub taking steep corners at high speed or at the track (there are a few pix on my AutoX thread that prove that)
Old Jun 8, 2009 | 05:38 PM
Loi's Avatar
Loi
Are you running the same tire sizes in that picture? and you have spacers too right? I don't have spacer.
Old Jun 8, 2009 | 05:44 PM
G37Sam's Avatar
G37Sam
Well not the same exact one but if 245/40 rubs then the 245/45 will definitely rub
You should be fine on straights though
Old Jun 8, 2009 | 07:37 PM
DrJones's Avatar
DrJones
yep i agree
Old Jun 8, 2009 | 08:01 PM
HamstersG's Avatar
HamstersG
Sam, you rub with 245/40 and NO spacers? I can see you rubbing with 245/40 and 20mm spacers on hard corners. I am running 245/40 in the front with 15mm spacers and have no rubbing at -0.4 camber no matter how hard I corner.
I do have rubbing on 275/35 with 15mm spacers at -0.9 camber in the rear and large dips / bumps. Rubbing is against the lining that I need to trim.
Old Jun 9, 2009 | 04:01 AM
G37Sam's Avatar
G37Sam
I wouldn't know because the spacers came in before the tire upgrades. But I believe with an eibach drop and crazy cornering you will rub in the front at least
Old Jun 9, 2009 | 10:48 PM
WhiteG37S's Avatar
WhiteG37S
Couldn't say if it will or will not rub, but can say it will look STUPID..DONT DO IT!
Old Jun 10, 2009 | 09:51 AM
w0ady's Avatar
w0ady
thats because you are running the wrong tire size - like everyone said go to 245/40/19. im running that with 15mm spacers and a eibach drop with NO issues, including some hard mountain road driving.
Old Jun 10, 2009 | 09:56 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I am running 245/40/19 on the front stocks- no spacers. I included an offset in the rear with 275s- agaiin no spacers. I am on a Tanabe drop. There is no way it will possibly rub. The eibach drop is a little more agressive but not too much more. I can't envision how it would possibly rub without spacers.
Old Jun 10, 2009 | 10:46 AM
w0ady's Avatar
w0ady
maybe his alignment is off too? who knows.
KAHBOOM
Aug 25, 2015 11:05 AM
Gio37
Aug 16, 2015 10:12 AM
RoyalG37
Aug 11, 2015 12:21 PM
zzww1251
Aug 8, 2015 06:19 PM
Rubyq60
Aug 3, 2015 10:36 PM
