Inner Tie Rod Dilemma
Have a bent driver inner tie rod... cannot find proper replacement... have tried a few inner tie rods and all are too big to fit with the steering rack.
2008 G37 S Coupe
Steering rack was replaced in 2012 with 49001-JL07E
for whatever reason the inner tie rod ends are smaller on this one. Anyone else run into this? dealer is useless...
Thank you all!
2008 G37 S Coupe
Thank you all!
2008 G37 S Coupe
Thank you all!
2008 G37 S Coupe
Thank you all!
2008 G37 S Coupe
Thank you all!
2008 G37 S Coupe
Thank you all!
One option is to buy each of the possible tie rods and return the ones that dont fit. Moog parts are rock solid.
https://www.rockauto.com/en/moreinfo...446983&jsn=297
as an example, this is from rock auto. I have makes the relevant information:
AAnd this being from moog's website for the 370z tie rod, which we know is an M18x1:
Your best bet is to measure you rack side stud prior to ordering and base the order on the model year that the size fits into (aka if you have a 2012 but it measures M18, then order a pre 2011 tie rod)
grateful2923 (03-04-2024)
Spadds76
06-11-2018 10:14 PM
vuedoo
07-21-2014 11:19 PM
