18" 7.5" rims on staggered rims
hello,
i bought the 18" rims from my friend and they are 7.5" wide. is it possible to run a staggered setup with 225/50-18(front) & 245/45-18(rear) with the 7.5" rim without any problems or looking funny? its an unmodded 09 g37x. i found a good deal for those tires and don't want to pass them up. originally i had 225/55-17 on the g37x but I'm trying to upgrade them to 18s. i did the tire calculator readings and it showed that i was fine. any input is greatly appreciated.
thanks
thanks
It's OK but not ideal, the 7.5" rim isn't a great mount for a 245, a bit of a pinched mount resulting in sidewall roll under heavy cornering. The diameter variance is OK now, the rears are a bit shorter and will wear faster over time so the variance will increase, so that could cause issues w/ the AWD system if it gets over 1%.
dang I found that set almost new for $200. I figured I would Check to see if it worked out. I read that would be the typical set up 225/45&245/45 on 18s but didn't know if it worked on nonstaggered wheels. I read 245 are fine at 7.5" max. Would 245/45 or 235/45 all around be ideal?
Thanks again for the reply
4DRZ
Oct 14, 2015 01:51 PM
