Official Low Offset/Hellaflush Thread
Old Jun 2, 2012 | 07:50 PM
  #1456
Robert_K's Avatar
Robert_K
New to the G37S sedan and curious of the normal offsets for a 19x9.5 & 19x10.5/11? Not looking at all for the hellaflush/stretched tire look. But don't want a "too" aggressive "fat" tire. Just a nice lip for a three piece wheel and nice tire sizing.
Old Jun 2, 2012 | 08:05 PM
  #1457
Robert_K's Avatar
Robert_K
Originally Posted by DPE G
Hard to follow up after TreSe7en, but here we go...
What are your sizing, offsets and tire sizes? Looks real good!
Old Jun 3, 2012 | 09:30 PM
  #1458
VA_55's Avatar
VA_55
Work t1s Varianza (sbc)
F: 19x10 -20 * 215/35 * camber -5.5 * 4.5inch lip * front fender naturally pulled
R: 19x11 -7 * 235/35 * camber -7 * 5inch lip * rear fender pulled
Spc camber kit F&R
BC coilovers Full stiff with extra bump stops*
Old Jun 7, 2012 | 05:03 AM
  #1459
xr0ckstar's Avatar
xr0ckstar
20x9 +36 front
20X10 +25 rear
225/35
245/35
federal 595evo
how much of a spacer should I put up front ?
Old Jun 7, 2012 | 06:11 AM
  #1460
Robert_K's Avatar
Robert_K
From the research I'm gathering I'd do a 5mm and replace with more rubber.
Old Jun 7, 2012 | 08:12 AM
  #1461
Can'tGme's Avatar
Can'tGme
I remember your Z from when I was on My350Z! I'm not too sure about sedan offsets since I drive a coupe but scroll through this thread and see what other people are running. Post pics too!
Old Jun 7, 2012 | 08:41 AM
  #1462
Robert_K's Avatar
Robert_K
Think I'm pretty set of a 19/20x9.5 +30 & 19/20x10.5 +40 with a 255 & 285 tire.
Old Jun 7, 2012 | 09:32 AM
  #1463
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
I ran a 19x9.5 +25 in the front on my sedan, to get to that you need to be around +20 on a 9. So you really need a 15 mm spacer, not a 5.
Old Jun 7, 2012 | 03:54 PM
  #1464
TreSe7en's Avatar
TreSe7en
^+1, at the minimum a 15
Old Jun 7, 2012 | 03:59 PM
  #1465
TreSe7en's Avatar
TreSe7en
^umm what...? (checks to make sure if in right thread)
Old Jun 7, 2012 | 04:07 PM
  #1466
Robert_K's Avatar
Robert_K
Yeap... Misread a 20x9.0 for 20x9.5. But still you all are recommending a +25/+20 offset on the front of the sedan?
Old Jun 7, 2012 | 04:30 PM
  #1467
P Casey's Avatar
P Casey
Not too aggressive in rears(nh) but widths and tire sizes are not bad. I think many more should start running this widths, I am not even stretching much at all. Imagine the width and offset combo we can start running. Im thinking +15 all around 20x10.5 will be perfect.
20x10.5 +27 265/30 front will be adding 5mm spacer tomorrow still a lot of room. Camber -1.8.
20x10.5 +27 with 5mm spacer +22 265/30 rear. Camber at -2.5
Old Jun 7, 2012 | 04:35 PM
  #1468
Robert_K's Avatar
Robert_K
I think 265 on a 10.5 is stretching. Just to share what I've done to my 350Z...
Satin Black HRE P43SC wrapped in Toyo R888* tires.
19x9.5 +20 265/30
19x11 +25 305/30
KW V3 coilovers w/ SPL front upper camber arms & SPL rear camber links.
*R888 tires run big so you "could" say they are a 275 & 315.
***Pictures are before alignment.***
Old Jun 7, 2012 | 06:23 PM
  #1469
xr0ckstar's Avatar
xr0ckstar
thats what i was thinking at least a 15mm . do you have pics of that setup ? did you need to roll the front fenders ?
Old Jun 8, 2012 | 09:51 AM
  #1470
TeRRoRiFiC35
Can't post pics right now as I usually only come on here during work on my iPhone. If you look at the 3 piece wheel post, I have pics in there. You will be sitting very close to flush maybe a little aggressive with the need of camber. I was running 0 camber in my pics but I maxed out the toe arms to get my wheels like they were. I didn't roll the front because I was running a 2 finger gap first then the springs settled with 1 and I was fine with that. I was running decently aggressive just not anywhere near what I could have. I don't think these sedans look right with massive amounts of camber in the rear.
