Official Low Offset/Hellaflush Thread
Old Dec 9, 2016 | 11:23 AM
  #2161
2011-G's Avatar
2011-G
Looks dope!!!
Do you guys think I can fit a 20x10 with a +45 offset in the front with a 255 tire? Is it going to rub against the fender with a mild drop?
Old Dec 9, 2016 | 01:09 PM
  #2162
b-drizzy's Avatar
b-drizzy
depends on the drop
you on coils or springs ?
Old Dec 11, 2016 | 12:29 PM
  #2163
b12G's Avatar
b12G
Hey guys, new to the forum here I own a 2012 G37 Coupe... I have a set of Avant Garde wheels specs are:
19x9.5 +15 (front)
19x11 + 18 (rear)
I will be on HSD Coilovers soon and have front and rear camber arms, im just wondering how i can run this setup without too much camber to stay away from uneven tire wear, i know i will have some regardless as these are very aggressive offsets. just need to hear some G owners opinions lol. Need to know what tire size to run and what alignment specs also.
Here are a few pics of the wheels on the car without tire.
Thanks guys!
This is the rear wheel poke
This is the front wheel poke
Old Dec 12, 2016 | 09:07 AM
  #2164
VenomGT9's Avatar
VenomGT9
you're probably gunna need some pretty decent rubber bands if you want minimal camber
I'd expect about -2 to about -2.5 in the rear...could probably run a 265/35 without rubbing
Old Dec 12, 2016 | 11:06 AM
  #2165
b12G's Avatar
b12G
Thank you Venom, when you say "decent rubber bands" are you talking about money to spend lol I want to stay away from any body work. I don't mind running a stretch tire and will not be slammed will ride on a moderate height to avoid any scrapping/rubbing.
Old Dec 12, 2016 | 03:40 PM
  #2166
2011-G's Avatar
2011-G
Originally Posted by b-drizzy
depends on the drop
I will be getting coilovers so I can adjust the height accordingly if this set up fits
Old Dec 12, 2016 | 04:13 PM
  #2167
VenomGT9's Avatar
VenomGT9
rubber bands as in low pro tires
245/35 and 265/35 would probably work
Old Dec 12, 2016 | 06:23 PM
  #2168
b12G's Avatar
b12G
Thank you buddy, will post pics when i get tires. Can't wait to see how this looks!
Old Dec 27, 2016 | 10:14 PM
  #2169
VQCrew's Avatar
VQCrew
Can anyone tell me if 19x10.5 +22 squared on g37x sedan will fit with 245/40 tires at 26 inch fender to ground height and be able to run about -3.5 degrees of camber in rear without pulling the fenders? Also thinking about possibly stretching a 235 but idk, seems too much/unsafe?
Old Dec 29, 2016 | 11:34 AM
  #2170
b-drizzy's Avatar
b-drizzy
youll be fine but in the front you wil run camber forsure
I had 245/35 in my rears on 10.5 +12 with -6 was pretty low though as well, dint pull no fender in the rear
I woldent go with 235, tire can pop out
and for the front you might need some fender work if you don't camber, you will rub
Old Dec 29, 2016 | 11:56 AM
  #2171
2011-G's Avatar
2011-G
Yo B drizzy - Is that a reply to my post or you're getting back to VQCrew?
G37 sedan with 20x10 with +45 offset wrapped around in a 255 or even 245/35? Will it rub? will it clear steering knuckle without the spacers. I do not want to run camber in the front.
Old Dec 29, 2016 | 01:08 PM
  #2172
b-drizzy's Avatar
b-drizzy
that was reply for VQ crew, sorry
and for 2011-G, it depends on how low you go
Try a 235/35
I suggest with hankook since they run true
other tires might sit high and you can run into rubbing
even if you don't run camber arms with a drop you will still get natural camber
Just make sure to alight it after wheels go on, Shouldn't be much since you will be on 20"
Old Dec 29, 2016 | 05:56 PM
  #2173
VQCrew's Avatar
VQCrew
For the front, will -3 camber be enough? because I have stock control arms and that's the natural camber I had from lowering it. Also, how much do you think I would have to pull the rear fenders to run about -3.5 degrees?
Old Dec 30, 2016 | 11:50 AM
  #2174
b-drizzy's Avatar
b-drizzy
Theres not much pulling for us, its pretty much going to flare
But it would be a little hard to tell since I cant see in person how it will turn out once its installed
Old Jan 2, 2017 | 11:06 AM
  #2175
MaQG37's Avatar
MaQG37
b-drizzy - When you ran 10.5's +22 on your rear with 255's, did you ever come in contact with the fender? Did you just have the fender liner trimmed?
