Official Low Offset/Hellaflush Thread
Old Feb 18, 2016 | 09:31 AM
  #2056
Swaggy G's Avatar
Swaggy G
Alright I probably won't go that route then. Thanks man
Old Feb 18, 2016 | 06:13 PM
  #2057
VQCrew's Avatar
VQCrew
So I thought I would see how 1 inch spacers look with 19x9.5 +20 wheels just for fun... I think it may be too much, anyone know how much camber will I need and I will have to pull fenders if i want to run this?
Old Feb 19, 2016 | 11:38 AM
  #2058
b-drizzy's Avatar
b-drizzy
you need smaller, stretch tires
Coils
and about -7 camber at least lol
And huge pull from the rear
just get bigger wheels lol
Old Feb 20, 2016 | 11:56 AM
  #2059
VQCrew's Avatar
VQCrew
Coils
Yeah, it was just to see how it would look, definitely not gonna try to run it. I'll just get some 10mm spacers for the fronts and camber the rears a bit more for this season. For next season, I'm thinking I'll get some 19x10s with low offset.
Old Feb 23, 2016 | 04:30 PM
  #2060
b-drizzy's Avatar
b-drizzy
yeah that's some good thinking lol
or 10.5 always sits perfect with some mid offsets as well too
Old Mar 1, 2016 | 02:12 AM
  #2061
evil-G-nius's Avatar
evil-G-nius
Its weird...that first pic...the back wheel looks photoshopped! LoL. I like the side view but I think the wheels stick out too far for my taste. Other than that not a bad looking set of wheels for the sedan
Old Mar 1, 2016 | 06:27 PM
  #2062
VQCrew's Avatar
VQCrew
error&885xno_nocodefound
Old Mar 3, 2016 | 02:57 PM
  #2063
bluntz617's Avatar
bluntz617
coming from a pretty non aggressive setup of 255/285. Finally going 3 piece and ordered new wheels. I would love some advice on Tire size, best tires for stretching, I would love to to do a 225/255 setup but not sure if the 255 will fit without running too much negative camber. Would really appreciate any advice or suggestions you may have. My wheels specs are in the image below.
Old Mar 4, 2016 | 01:14 PM
  #2064
b-drizzy's Avatar
b-drizzy
is this going on a coupe ?
Old Mar 4, 2016 | 01:16 PM
  #2065
bluntz617's Avatar
bluntz617
Yes these are for a coupe
Old Mar 5, 2016 | 07:41 PM
  #2066
OfficialG's Avatar
OfficialG
I'd also like to know the answer to this as I am in the same boat. I usually run Hankook v12s for my stretching needs but I can't find 225/35/20 size anywhere for some reason....
My wheels are 20" 9.5 -11 and 10.5+12. I am on air and running some negative camber.
I would like to know what tire brands in sizes 225/35 and 245/35 have a similar stretch and lifespan as the hankooks in those same sizes.
Thanks.
Old Mar 6, 2016 | 09:15 AM
  #2067
bluntz617's Avatar
bluntz617
Anyone?
Old Mar 6, 2016 | 11:28 PM
  #2068
Ryne's Avatar
Ryne
The Steering Wheel Guy
Anyone?
I have 255/35R20 on a 20x10.5" +25 wheel on my coupe and it's a tight fit already. Camber is about -2. I'd say you are going to have a lot of work to fit those wheels. Probably need to use Falken tires, as they run tiny and stretch. You will also probably need a crazy amount of camber and frequent tire replacements. Maybe every 5k or so since the contact patch will be about that of a Civic. You will need to gut most of the fender liner also. I don't have any advice for fitting those front wheels. Maybe like -15 degrees of camber and a ridiculous amount of stretch?
Old Mar 7, 2016 | 02:01 AM
  #2069
bluntz617's Avatar
bluntz617
not according to this
I'm running +15 on a 10.5 inch front w a 255/30 and still have room! I do not have any aftermarket camber arms anymore and sits so beautiful. I did the 265/30 on the +15 but started to rub when slammed! I couldn't really turn until I raised but I like it low 255/30/20 was a perfect match! So yes you will be fine on that with a 265 maybe even a 275/30.
275/30 has been tested on front 10.5 +25 w out rolling fenders and no camber kits and again very successful while being low to the ground. Many many options these days
Old Mar 7, 2016 | 12:51 PM
  #2070
b-drizzy's Avatar
b-drizzy
The Fonts youll fit then that's no problem
I fit a 19x10 on my sedan and sat fender to lip nicely
So on a coupe your fine, Just shave off that fender liner
Rears just might need some minor pull and run some negative camber about -6 max id say depending how low you go that determines a lot too plays work in this.
for tires Go hankooks all the way
Front your fine with a 225/35
Rears go with a 245/35 it will be a legit stretch so make sure to have good tires I ran that before and just don't hit pot holes and invest in good tire brands lol
rears youll need a 8-10mm pull hopefully
