Official Low Offset/Hellaflush Thread
Old Jun 10, 2015 | 01:37 PM
  #1996
Wangstas863's Avatar
Wangstas863
Trying to it get it 25 3/4in or 26" inch from top of fender to ground , all around.
Old Jun 11, 2015 | 04:16 PM
  #1997
deathtrap's Avatar
deathtrap
Originally Posted by Wangstas863
Good mornin' every1. Quick question. Getting Vossens install today....wondering if it would require a fender pull. Getting the vfs2 satin bronze in 20x9+32 and 20x10.5 +45 with 245/35/20 & 275/30/20 . With stance coilovers & spc F + R camber kit. Can I go 25.75" or 26" all around or how low b4 fender pull required?
Those are pretty weak offsets. You don't need to pull a thing, you probably dont even need to trim the rear bumper bracket. Just bolt em on and be done.
Old Jun 22, 2015 | 12:56 AM
  #1998
Peepz's Avatar
Peepz
Couldn't wait for a camber kit or fender roll so I decided to just throw em' on anyway. Can't wait to see my rear fenders in a week. I'm stupid I know.
Taken with a Galaxy Note 4
Old Jun 23, 2015 | 11:14 AM
  #1999
b-drizzy's Avatar
b-drizzy
looks good bruh!
those the 19x11 in the rear
What are you drop on ?
Old Jun 27, 2015 | 02:49 PM
  #2000
Peepz's Avatar
Peepz
Originally Posted by b-drizzy
looks good bruh!
Thank you! And im dropped on Megan Coils and yes 11s rear.
Old Jul 4, 2015 | 01:44 PM
  #2001
kdawg8526's Avatar
kdawg8526
do those wheels clear bbk?
Old Jul 10, 2015 | 09:24 AM
  #2002
beachbum718's Avatar
beachbum718
I'm currently stretching 245 35 20 achilles atr2 on 20x11 and need a little more stretch.should I go down to 235 35.or run a 245 35 20 tire that runs small. Like toyo extensa or nankang??? I'm maxed out at camber as well.lol
Rear tire will only go fender to rim lip if I spray tire with tire wet/tire gel.
Old Jul 10, 2015 | 07:46 PM
  #2003
b-drizzy's Avatar
b-drizzy
dammm bro, your m is just boss!!!
Old Jul 10, 2015 | 08:14 PM
  #2004
beachbum718
Thanks.can you help me out with my questions?
Old Jul 12, 2015 | 07:51 AM
  #2005
Ipp391's Avatar
Ipp391
Bruh, that M looks ridiculous... Well done. As far as for narrower tires, you can go with Vredestein Ultrac Sessantas which run pretty narrow.
Old Jul 13, 2015 | 12:34 PM
  #2006
b-drizzy's Avatar
b-drizzy
Yeah lol sure, But if you go lower go with hankook tire, or even at any size I strongly recommend them. they run true and that's what you want.. don't go with toyos, or nankang, cheap routes will lead you to expensive fixes lol, trust me,
Maybe falkens too they are ok to run.
so yeah if you want more stretch go with the 235- just carefull on the potholes, Hope this helps
Old Aug 29, 2015 | 05:10 PM
  #2007
propho's Avatar
propho
I've got a 2009 G37S Coupe.. I've got a set of Maido GR5's that I refinished(new barrels, powdercoat, and tires) and intended to put on my G35 until I was rear ended and my car got totaled.. I test fit the rears and they stick out a lot but this is still on factory suspension. I will be purchasing coilovers.. Need suggestions on what I can do to remedy this.
Wheels specs are:
Front: 20x8.5 /w 255/30 (not sure the offset but the test fit didn't seem too crazy and had just enough to clear the calipers)
Rear: 20x10.5+29 /w 285/30 (https://goo.gl/photos/45jKwkE2NK9Lx6Se9)
Please no commends on the lugs, I am not really liking how they look now.. I originally purchased them to match my gold Brembos
Any and all input would be appreciated, including what parts I need etc..
Old Aug 31, 2015 | 12:21 PM
  #2008
b-drizzy's Avatar
b-drizzy
MAke sure to buy rear camber arms and then just alight it
Old Aug 31, 2015 | 05:44 PM
  #2009
propho's Avatar
propho
Thanks, I got ISC Coil's and an SPC camber rear camber kit coming to me..I just hope I don't have to camber like crazy for it..
Old Sep 1, 2015 | 11:37 AM
  #2010
b-drizzy's Avatar
b-drizzy
shouldn't too much
I ran 19x10.5 +22 on my sedan rears,
was pretty low where it sat fender to lip on wheel, tucking tire and was running -5 camber
you have 20 so it will sit you a bit more higher so bit less camber just depend how low you go.
