Hey, looking for some info and thought this would be the best place to get an answer, Has anyone run a 19x9.5 +20 offset or similar on a sedan that has some pictures, and what was needed to make it fit. Found the perfect set of wheels for my Sedan, but they only come in those offsets, and am trying to convince myself they will fit lol. Any info would be great, pm if needed.
FWIW, i ran 18x9.5+38 and the wheels were already slightly sticking out on OEM alignment specs. Roughly an Eibach drop.
For +20, you will need a stretch and some decent camber to get it to work.
welp, i cant compare to the outrageous negative offsets here , but running +25 with 275 rear and -5.2 rear camber in this setup. figured id toss it in anyway.. enjoy.
why so much negative camber???? you could be in spec with those tires and offsets
now that i think about it, im pretty sure they're your prior coils lol. just installed them last weekend, same height they were left at, and as soon as it was dropped it went right to that camber.
LOL!!!! I was about to say yea that was me that sold them to you... sorry I had them riding hella low lol! I was at -5.2 camber too haha
Hey guys, I just installed my Volks, 20 x 9.5 +15 on the front. Its hitting something i cant find it for the life of me. All i hear is a very annoying ticking sound, like a flap is loose and its touching everytime the wheel spins. Its coming from both sides. Im dropped on g35 H-Techs btw. Any of you have any idea?
Hey fellas, trying to see if I should squeeze a 15mm spacer on the rear making my current rear set up 19x10 + 20... Would a 255/35 do the trick? Rear bracket has been shaved and im dialed at -1.5 camber....
