Help Removing TPS from wheels...plz help!
Old Feb 26, 2009 | 12:55 PM
terrycs's Avatar
terrycs
Originally Posted by aliiin
not if you're lucky and hit the right one on the first try
I asked the shop if it would make a difference and they said no. So to prove it, I watched them intentionally move the fronts to the back and swapped sides as they were moving them from my stockers. No difference.
Old Feb 26, 2009 | 12:58 PM
aliiin's Avatar
aliiin
BMW Defector
wait huh? i meant if you get the tpms light... and you have low pressure in 1 tire, then you'd have to check each tire... but if you hit the right one... you don't have to check all 4?
Old Feb 26, 2009 | 01:02 PM
terrycs's Avatar
terrycs
O! Sorry .. thought you meant the shop might have put mine back in the original spots. But I'd still chack all four if I got a light!
Old Feb 26, 2009 | 01:33 PM
Kidcane's Avatar
Kidcane
Florida G Club
OK that is what I thought. Since our car does not say specifically which tire is low but instead that one of them is low that it should not matter that you dont put them back where they originally came from. Good to know. Thanks.
Old Feb 27, 2009 | 12:50 AM
machinist's Avatar
machinist
Terry...that's great info bud. Thanks a lot for that. I was getting kinda worried about getting them in the right wheel. I just hope they're compatible with Vossen wheels!
Old Feb 27, 2009 | 01:46 AM
terrycs's Avatar
terrycs
It depends on the barrel section. There is a company that also makes various adapters to get them in there. Because of the way the valves sit on my 20" DPE wheels, they drilled holes for the TPMS on the inside section to take advantage of the clearance.
Old Feb 27, 2009 | 08:24 AM
machinist's Avatar
machinist
Terry, thanks bud. Would you happen to know the name of that company that makes the variable sized adaptors?
Old Feb 27, 2009 | 09:23 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^You can also remove the sensor from the valve and strap them inside the wheel with metal straps. Thats what I finally did on my Maya's.
Old Feb 27, 2009 | 10:25 AM
IvoryG's Avatar
IvoryG
Originally Posted by terrycs
Mine are mixed and matched all over my car with no error lights. The G's BCU does not display which tire is low on air like the M does. However, if you happen to have a CONSULT III attached to the car, it will display which sensor is giving the error code.
In short, your sensors will work fine no matter which corner you have them on. You get a low pressure icon if any ONE of the sensors picks it up, so you end up having to check all four tires anyway.
The factory service manual says the sensors have to be programmed in a certain order (FL,FR,RR and RL). And they have to stay in that order to not throw a light. They work in series.
Old Feb 27, 2009 | 10:32 AM
www.tpmssolution.com
Old Feb 27, 2009 | 09:08 PM
machinist's Avatar
machinist
Sweet...thanks Jeremy!
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
MrRiv
Sep 29, 2015 04:59 PM
VIVID
Sep 29, 2015 10:58 AM
philttz
Sep 21, 2015 11:12 AM
