Camber kit questions
Old Nov 22, 2007 | 10:56 PM
fcarpio's Avatar
fcarpio
What is a camber kit? If I drop my car, would I need a camber kit? If I do not get a camber kit due to not being available for the G37 yet and drop my car, am I going to have ride quality and tread wear issues?
Please advise.
Old Nov 23, 2007 | 07:34 PM
fcarpio's Avatar
fcarpio
Anybody?
Old Nov 23, 2007 | 09:23 PM
siug37's Avatar
siug37
A camber kit will allow you to put your car's camber to the correct specifications after altering the ride height of the car.
You will effect your camber when you lower your car. How much camber adjustment you need depends on how low you go with the car.
If you do not get a camber kit, you will burn through tires a little faster. Way too much camber might result in the *** end of the car jumping around when hitting bumps.
To my knowledge nobody makes a camber kit yet for the G37.
Old Nov 24, 2007 | 04:01 AM
terrycs's Avatar
terrycs
Eibach has a rear camber kit for the G37.
Old Nov 24, 2007 | 06:06 AM
fcarpio's Avatar
fcarpio
Ahh, I also have a blue slate, but mine is a coupe. Can you please post a larger picture of your car with those wheels???
Thanks to both for the replies.
Old Nov 24, 2007 | 10:50 AM
siug37's Avatar
siug37
Sweet. i didn't know that.. I guess Ill have to buy that for my spring install.
Edit: I guess nobody is selling it yet.. Can't find it on a few websites I went to and Eibach doesn't list it.
Old Nov 24, 2007 | 02:28 PM
terrycs's Avatar
terrycs
Here is the thread with a bunch of pictures and information -
http://g35driver.com/forums/showthread.php?t=175452
I'll check with Eibach for you on the rear camber kit - I'm pretty sure it's the same one that is used on the 07 G35 sedan. I know that a camber kit was recently fitted onto a forum member's G37S recently. Here is the thread about his car:
https://www.myg37.com/forums/brakes-and-suspension/175172-eibach-pro-kit-done.html
I actually still need to find out what the status is on front camber kits anyway.
Old Dec 14, 2007 | 02:46 PM
symalik's Avatar
symalik
any updates on the camber kit?
Old Dec 14, 2007 | 11:32 PM
terrycs's Avatar
terrycs
I received an email from Eibach on 12/5. Still nothing yet from their supplier, SPC.
Old Dec 15, 2007 | 01:23 AM
solopresident's Avatar
solopresident
blaahhh i neeed one sooo bad
SBG37
May 5, 2022 10:35 AM
GFTW
Nov 11, 2015 02:56 PM
equifire
Aug 31, 2015 03:42 PM
Ipp391
Aug 28, 2015 09:27 AM
kyro840
Aug 9, 2015 01:38 PM
