tirerack.com winter tires for boston
Old Oct 28, 2007 | 06:46 PM
rrrevin's Avatar
rrrevin
Has anyone who ordered from Tirerack recevied their tires and can confirm that the combo they ordered fits or not?
Old Oct 28, 2007 | 08:31 PM
COUPE-DADDY's Avatar
COUPE-DADDY
I would like to know myself....
Old Oct 28, 2007 | 09:25 PM
joeposter's Avatar
joeposter
Originally Posted by InfinitiFreak
I need to get a floor jack too, anyone know where I can get one that is low enough to get under the G37.
I have no personal experience but one mentioned here might be an option...
I think that for winter tires it is always best to go down one size, so I would go with the 18" tire package.
I agree. Check out the tread width of the 18's vs the 19's. They're more than an inch narrower which helps a lot. Unless you like the thrill of hyrdoplanning down the highway in slush.
Old Oct 30, 2007 | 06:10 PM
G37RacerX's Avatar
G37RacerX
Bump!
My past orders from tirerack.com arrived within 3 - 5 business days...
Old Oct 30, 2007 | 07:30 PM
Orbie's Avatar
Orbie
I just received my winter tires/rims from tirerack, I haven't had a chance to try a test fitment though. I probably won't be able to get to that until the weekend. Odds are BM or one of the others will test fit before me. I do have to say the Sport Edition A7's do look a bit small for the brakes, but they are cut much deeper on the inside then the front face shows, which is probably what allows it to fit.
Old Oct 30, 2007 | 07:49 PM
Comatose's Avatar
Comatose
great, please keep us posted! My main concern about the A7's was that tire rack had listed them as a +35mm offset.. which hopefully im mistaken, but I believe that would result in the wheels sticking out...
Old Oct 31, 2007 | 08:36 PM
bostonmerlin's Avatar
bostonmerlin
i received my tires/rims yesterday.. no plans to install for another few weeks though
Old Nov 7, 2007 | 07:47 PM
bostonmerlin
picked up a low profile floor jack from sears the other day. it's getting cold in boston these days.. about time to put those tires on. I hope they fit!
anyone else get their winter tires on yet?
Old Nov 7, 2007 | 08:20 PM
Garnet Canuck's Avatar
Garnet Canuck
Traveling Administrator
I haven't put mine on either yet, but will sometime before the end of the month.
Old Nov 7, 2007 | 08:42 PM
bostonmerlin
I thought it started snowing in Canada in May!
Old Nov 7, 2007 | 10:01 PM
shumby's Avatar
shumby
Don't laugh i am looking at 2" of snow right now I got cought in a snow storm Last Saturday night in my G only got it on thursday. I am getting 18" rims with Michelin Pilot alpins put on tomorrow will post pics after they are on. By the way My pics are always too big to post how do you attach big pics like the guys did for the Sema show?
Old Nov 7, 2007 | 11:12 PM
InfinitiFreak's Avatar
InfinitiFreak
Which jack did you get, I still need to find one. Is it low enough to fit under the G?
Old Nov 8, 2007 | 11:45 PM
joeposter's Avatar
joeposter
I don't see any problem fitting most floor jacks under a stock G37.
I just installed 4 225/50HR-18 Bridgestone Blizzak LM-25 mounted on 18x8 Sport Edition A7 Silver wheels. They came to $1,258.54 delivered from Tire Rack.
Couple things to point out...
The stock lug nuts won't fit in the deep, narrow holes in the rims. Narrower lug nuts were included along with a lug adapter since most lug wrenches are too fat for the holes too.
There's a 12mm bolt on the front rotors that has to be removed for the rims to fit. The salesman at Tirerack said this was to hold the caliper during repair but I think it prevents you from putting the back tires on the front by mistake.
Rotor clearance was no problem (close to 1.5 inches) The caliper clears by about 3/8's of an inch.
Attached Thumbnails tirerack.com winter tires for boston-caliper.jpg   tirerack.com winter tires for boston-bolt.jpg
Old Nov 9, 2007 | 09:42 AM
  #29
InfinitiFreak
Ok, thanks, just did not want to get a jack that would not be able to clear the car. I test fitted one of my winter tires on the car last weekend, but I just used the jack that came with the car. I noticed that bolt to, unfortunately I was not told to take it off, LOL, however after like 15 minutes of trying to put the wheel on, I figured it out, felt stupid! I was happy to see that the tire cleared the calipers. Did you use the jackpoints on the side, or did you jack the car up from the front, because I looked under the front and did not really see a safe place to use to jack up the car.
Old Nov 9, 2007 | 11:35 AM
  #30
tomcat146's Avatar
tomcat146
Looks good !! Did you use the tire pressure sensors that were on the stock wheels ? I want to buy 4 TPS for my winter wheels but they are $102 each. Does anyone know if you could buy the G35 TPS and have them work ? The service guy i talked to did not know the answer!!! Also, do you know if the tire pressure light could be easily disabled if i decided to buy a set of after market sensors ?
