Help p101a MAF
Old Mar 5, 2020 | 07:27 PM
racer808's Avatar
racer808
p101a MAF
I am chasing a p101a MAF sensor problem on my 2011 g37. Car runs perfect, idles steady. Cant find any leaks, I've cleaned the throttle bodies, clean the MAP sensor, cleaned the MAF sensors. I was actually rather impressed everything was clean to begin with but I did my due diligence & cleaned it all. I can't imagine these sensors being bad & I don't want to just throw money at it. Dealer thinks the throttle bodies themselves need to be replaced. Is that a common solution? Is there anything else I should be looking for? Stumped on this. Car is very clean, low miles ECU was just updated.. Thanks in advance!
Old Mar 6, 2020 | 08:18 AM
SonicVQ's Avatar
SonicVQ
I think you have a typo in the code, a P101A does not exist for a 2011 G37.
Old Mar 6, 2020 | 09:48 AM
racer808's Avatar
racer808
That's what they printed out but I agree I can't find that code anywhere in my google searches. Either way it's a MAS fault that I can't figure out. I can't imagine the throttle bodies being bad, I'd like to trouble shoot every last possible issue before buying a new set of those
Old Mar 6, 2020 | 10:52 AM
BULL's Avatar
BULL
Moderador
P0101 is a valid code = Mass Air Flow Circuit Range/Performance
P101a is not but it could be a typo for p0101 A which could be MAF for bank A or bank 1
Dont know what your time range is and how long can you drive with the code however you should try to switch sensors from one side to the other to determine.
You can buy a Bluetooth OBD adapter and monitor the range of the MAF sensor and that will let you know if this is the culprit.
Old Mar 6, 2020 | 01:04 PM
racer808's Avatar
racer808
Ohhhhhh, thank you! That actually would make perfect sense with there being 2 sides. I will try that & see what happens.
robger99
General Tech Questions
Apr 25, 2022 08:54 PM
haleakalag
14
Jul 26, 2019 04:22 PM
Silver37
Dec 9, 2014 08:35 PM
venzz
Mar 4, 2013 01:43 AM
