63mm Bored TB's idle
Old Nov 2, 2019 | 05:45 PM
Dzionassi's Avatar
Dzionassi
Installed these yesterday, after install was idling at +-1000rpm's . Did a relearn procedure with Ecutek got it down to 720-750.
If I remember correctly, I was at 650 or so before install...
Question is... what is normal idle with 63mm TB's?
Old Nov 3, 2019 | 08:52 PM
jpowersjr2's Avatar
jpowersjr2
Not sure about that but you might need a re-tune.
Old Nov 6, 2019 | 02:27 PM
Surfnazi's Avatar
Surfnazi
You'll need a tune bc it's out of delta range for stock af
Old Nov 6, 2019 | 02:34 PM
Dzionassi's Avatar
Dzionassi
Log's looking OK...
Old Nov 11, 2019 | 05:23 PM
Surfnazi's Avatar
Surfnazi
Does log show full range of rpm
Old Nov 11, 2019 | 11:07 PM
Dzionassi's Avatar
Dzionassi
up to 7463rpms
Old Nov 12, 2019 | 09:07 AM
Surfnazi's Avatar
Surfnazi
Post up the log
Old Nov 12, 2019 | 10:01 PM
Dzionassi's Avatar
Dzionassi
attached
File Type: csv
Old Nov 14, 2019 | 04:06 AM
bythabay's Avatar
bythabay
20 Year Member
Knock sensitivity has been raised significantly (the ECU has been made more "deaf" to knock events).
AFRs are all over the place.
It's running pretty much stock timing or less than what it would run stock.
What fuel are you running? What other mods does this car have? Is this a rebuilt engine?
projectpanda13
Jun 4, 2024 03:25 PM
projectpanda13
Jun 4, 2024 03:22 PM
Eldredge253
Mar 8, 2019 10:28 AM
el_donks
Aug 14, 2018 03:18 PM
NeverBoneStock
Mar 12, 2015 11:03 AM
