Stillen G3 vs Admintuning Intakes
Old May 17, 2020 | 11:04 AM
  #91
Samy Cee's Avatar
Samy Cee
Originally Posted by AdminTuning
This is a good thread. If anyone has any questions they can reach out to me via email moncef.faik@gmail.com.
Does 3in intakes require upgrade injectors?
One tuner told me the stock injectors are maxed out so we need to replace them with aftermarket injectors. I’m currently tuned with Stillen gen 3 intakes.
Old May 17, 2020 | 11:19 AM
  #92
xnick101's Avatar
xnick101
NEED? No. Should you? Yes. I was at 90% injector duty cycle with 3" intakes, test pipes, full exhaust, ported upper manifold, and tune. I switched to OEM GTR injectors (make sure you do not get them off ebay as they are 100% fake). The bigger injectors also allows the tuner to be a little more aggressive and not worry about it leaning out, ie which is why the tuner is telling you to get them.
Being on OEM gtr injectors also allows you to tune for e85 if you want.
Jensen Geevs
May 10, 2021 01:51 PM
Klaus9
ECU Tuning / Dyno Data
Oct 3, 2020 05:18 PM
gclasslicense
Apr 13, 2020 11:13 AM
msonbolg37x
Engine, Intake and Exhaust
Jan 17, 2019 11:50 AM
mikep
Sep 10, 2018 02:04 AM
