plenum cleaning procedure?
Old May 18, 2015 | 01:54 PM
stevo4756's Avatar
stevo4756
Anyone have any suggestions for cleaning the upper plenum? Is this procedure even needed with 90k miles on the clock? Remove plenum and Flush with a couple cans of CRC throttle body cleaner ?
Should I replace the throttle body gaskets and plenum gasket since I have 90k miles?
I plan on changing spark plugs and cleaning anything intake related seeing that I have almost 90k miles now.
Thanks guys!
Old May 18, 2015 | 10:09 PM
ANMVQ's Avatar
ANMVQ
If you take it off I would do that to clean it. I would also clean ther TB's, change the gaskets, all of them and clean the MAF's. You might wanna clean the lower plenum ports also
Old May 19, 2015 | 08:49 AM
stevo4756's Avatar
stevo4756
Great info, I'll change the gaskets while I'm in there. Thanks.
Do you suggest I remove the lower plenum or just spray TB cleaner on a microfiber and scrub?
Old May 19, 2015 | 09:13 AM
ANMVQ's Avatar
ANMVQ
Cloth and cleaner should be fine, If you remove it tho there's a lot of work cleaning as you'll have to change that gasket also. It has a blk coating on the gasket that cooks onto the motor. When I swap my lower plenum I had to clean a ton plus , leaves and crap LOL
Old May 19, 2015 | 10:06 AM
stevo4756's Avatar
stevo4756
Oh boy, sounds like a blast. Lol. I might just clean TB and change plugs. Does the plenum collect a lot of gunk or mostly around where the TB bolts up?
Old May 19, 2015 | 04:32 PM
ANMVQ's Avatar
ANMVQ
No more in the runners and he bottom where it meets the lower plenum.
Heres a pic of mine when I swapped it
Attached Thumbnails plenum cleaning procedure?-ported.vs.stock2.jpg   plenum cleaning procedure?-intake-lower-before-install.jpg
Old Jun 2, 2015 | 08:28 PM
TheLocNar's Avatar
TheLocNar
Stollen Gen 3 intakes? What did you do do get them loose from the TBs? Any tips? I know I need to get mine cleaned and I'm just too lazy to do the work. lol Need to clean the filters too. Sigh!
Old Jun 3, 2015 | 01:35 PM
ANMVQ's Avatar
ANMVQ
Takedas same thing tho LOL just loosen both clamp and take them off the TB's a little wiggling and them come off .
The filters easy to just remove the plastic sheild over the radiator and take the 6 10MM nuts off the back of the grill take the grill off and take out the filters
Old Jun 3, 2015 | 01:52 PM
Flakman's Avatar
Flakman
Still haven't done this (just reached 100k). Worried about having to to TB position relearn.
Old Jun 3, 2015 | 02:28 PM
ANMVQ's Avatar
ANMVQ
Yea its a PIA but you only have to do it if you unplug them. I did that when I swapped out my lower plenum and the relean didn't work the first time. LOL car ran like crap and sputtered. :/ Had to re do it again last night
Old Jun 15, 2015 | 02:14 PM
TheLocNar's Avatar
TheLocNar
lol I remembered you had the Takedas after posting. Ok good. So no need to remove the whole damn system to get to the TBs. Phew. Thank you!
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
Stevolkz33
May 28, 2016 02:36 AM
Mr Infinit
Oct 16, 2015 09:43 AM
timc00k
Oct 9, 2015 01:20 PM
