Y pipe???
Old Jan 7, 2016 | 08:59 AM
  #61
jfisher's Avatar
jfisher
Originally Posted by stevo4756
I'm not sure about gains , but I just installed art pipes on my nismo exhaust with the factory y pipe and it sounds like crap. Sounds like the art pipes are buzzing . my guess is the oem y pipe that sits after the art pipes is causing turbulence / backup since it's tiny compared to the art pipes. Probably going to spring for $150 Megan / manzo y pipe... Ughhh frustrated.
Did you ever end up getting an aftermarket y pipe? I've always had a similar hunch to you as to the tiny piping on the y pipe being a big cause of the rasp when adding either HFC's or test pipes. I run resonated test pipes only and do have quite a bit of rasp with the stock y pipe.
Old Jan 7, 2016 | 09:01 AM
  #62
jfisher's Avatar
jfisher
Originally Posted by lorentzoe45
So I ended up getting the z1 hfc, z1 intake manifold, and tune. That's paired with my k and n intake and y pipe back exhaust. They ran almost 20 runs and I topped out at 297rwhp on my 2011 g37x sedan. Keep in mind the car still has stock y pipe which I will be replacing but they tried all the y pipes they had at the shop and none of them would clear the transfer case. As far as sound believe it or not it got better. If I could do it all over again I would of got the stillen gen 3 intakes and a y pipe that fits awd before I went and got it tuned. I have before and after videos if someone could kindly let me know how to post them. Also z1 has dyno videos and pictures that they are emailing me today. Very pleased overall. I gained power in every rpm. Rev limiter at 7900 and that is one of the best things really really helps top end just that little bit.
What did Z1 end up tuning your car with? ECUtek? I'm assuming they found some way to disable the AWD? Pretty damn good numbers.
Old Mar 30, 2016 | 02:08 PM
  #63
NeoNz's Avatar
NeoNz
Any word on the flowmasters 3" --> 2.5" midpipe install?
Old Mar 31, 2016 | 08:37 AM
  #64
jfisher's Avatar
jfisher
I saw that a user on here was successfully able to use an ebay 3" y pipe with his OEM midpipe. I'm debating on going that route here soon.
Old May 5, 2016 | 03:36 PM
  #65
NeoNz's Avatar
NeoNz
Any feedback guys? Looking to purchase the correct Y-pipe, given I will likely be going with either a Megan or TopSpeed exhaust for my G37x.
Which Y-pipe fits G37x?
bbillard1
Intake and Exhaust
Jan 23, 2016 10:43 AM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
rks
Sep 27, 2015 07:38 PM
Intake and Exhaust
Sep 24, 2015 09:22 PM
