After cleaning throttle bodies "issue" - Please help
Old Jun 20, 2011 | 02:59 PM
alhayem's Avatar
alhayem
Hi guys
I hope that you are fine.
One of my friends has a g35 sedan and he cleaned the
throttle bodies
Later on after he finished he faced this problem
as shown in the video
YouTube - ‪After throttle bodies cleaning g35 part2‬‏
YouTube - ‪After throttle bodies g35‬‏
I need your help to solve this problem.
Old Jun 20, 2011 | 03:23 PM
Kidcane's Avatar
Kidcane
Florida G Club
Not sure from the videos, what is the problem? Shifting at 2500?? High idle??
Old Jun 20, 2011 | 04:03 PM
VossenG37S's Avatar
VossenG37S
Not sure what we just saw looks normal to me.
Old Jun 20, 2011 | 04:16 PM
fluxemag's Avatar
fluxemag
I'm going to take a stab at this even though I'm not sure what I was looking at. He probably screwed up one of the MAF sensors (or both), or got cleaning agent on the sensors.
Old Jun 20, 2011 | 04:38 PM
rAiN's Avatar
rAiN
I think you need to reset the butterfly position
Old Jun 20, 2011 | 05:34 PM
alhayem's Avatar
alhayem
He cleaned the throttle (it comes after the air intake)
and the RPM is not stable
Old Jun 20, 2011 | 05:55 PM
rAiN's Avatar
rAiN
yeah, when he cleaned it. he must have messed with butterfly position which can result in unstable rpm. tell him to perform the butterfly repositioning procedure.
Old Jun 21, 2011 | 04:39 AM
alhayem's Avatar
alhayem
hi
mmm
can you explain that more please ?
Old Jun 21, 2011 | 05:00 PM
alhayem's Avatar
alhayem
up up up up
Old Jun 21, 2011 | 05:35 PM
rAiN's Avatar
rAiN
Throttle valve reposition
<TECHNOSQUARE - PRODUCTS - TECHNOSQUARE - 350Z ECU Reset>
Old Jun 24, 2011 | 04:05 PM
Austin713's Avatar
Austin713
if he disconnected the connector or any of the hoses while cleaning his idle is going to be messed up, and it will have to be reprogrammed. the procedure is in the FSM.i believe the procedure is the same for the 3.7 as well. its on page 16. the PDF is to big to attach, so if somebody wants to host it or if you need it i can email it to you. just PM me with your email.
Old Jun 25, 2011 | 09:06 AM
EnviedG35's Avatar
EnviedG35
I had a high idle on mine even though i never removed any plugs or anything either. I had to do a idle relearn and problem was solved
Old Jun 27, 2011 | 12:21 PM
BLKG37X's Avatar
BLKG37X
I had an Infiniti I35, and a guy who didn't know what he was doing cleaned the throttle boddies for me. He sprayed something inside, wiped it a bit. Afterwards, it idled at 1,900 RPMs instead of 750 RPMs. I went to dealership, and they reprogrammed it for me - good as new. The tech said the throttle boddies are not meant to be cleaned this way on our cars.
Old Jun 27, 2011 | 02:28 PM
pricojorge's Avatar
pricojorge
I want to clean mine so bad, but so afraid of this happening to me, i dont want to have to go to the dealer for them to fix it since Im not under warranty anymore =/
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
linvbro
Aug 22, 2016 01:25 PM
dedmanchan
Sep 24, 2015 11:25 PM
