Review R2C MaxFlow CAI
Old Apr 4, 2011 | 04:37 PM
  #151
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
nope you dont need to reset the ecu or disconnet the battery
Old Apr 4, 2011 | 08:09 PM
  #152
TVPostSound's Avatar
TVPostSound
Originally Posted by Dj farhan
got mine today! ;-D
Looks like UPS delivered it.
United
Package
Smashers.
Old Apr 4, 2011 | 08:38 PM
  #153
Steveo47's Avatar
Steveo47
UPS has NEVER sent me a undamaged box. Everything i have ever recieved has a small rip in it, maybe too look inside?
Old Apr 4, 2011 | 11:50 PM
  #154
wickedwyrm's Avatar
wickedwyrm
I got the intakes in. They sound great...One small problem. I dropped my 10mm wrench in the resonator box while tightening the mount. Is there a way to get to the resonator box without taking the bumper off. I don't really want to take it off, I think a new craftsman wrench is only like $5, don't really know if it's worth the hassle. I didn't notice any rattle from the wrench in the box while driving.
Old Apr 5, 2011 | 10:52 AM
  #155
DeamonG37s's Avatar
DeamonG37s
Good info on these intakes thanks for all who posted I'll prolly pick up a set soon of these.
Old Apr 5, 2011 | 01:10 PM
  #156
Djfarhan's Avatar
Djfarhan
United
Package
Smashers.
haha but the sller did an awesome job packaging it inside, so it was all good!
Old Jun 11, 2011 | 02:32 PM
  #157
weaver's Avatar
weaver
Quick question regarding the hoses from the motor. I didn't use the one supplied that shows to go on the passenger side, as I was able to use the one on the car. I did the same for the drivers side. My question is on the drivers side the picture doesn't show the hose connected to the intake tube. Does this need to be connected or not? I did everything else like shown and went for a test drive. Very impressed with sound and performance. Along with the grounding wires I am happy so far.
Thanks for the help with my question.
Old Jun 13, 2011 | 09:19 PM
  #158
RedG37SNC's Avatar
RedG37SNC
Yes, both intake tubes should be connected to the crank case hoses.
Old Jun 13, 2011 | 10:48 PM
  #159
nbarone's Avatar
nbarone
I installed these the other day and didn't use the long hose either, I was able to fit the tubes on the car into the intake. I do notice that the passenger side heat shield sits a little higher than on the driver side, anyone else notice this or is this a flaw in my DIY skills?
Old Jun 13, 2011 | 11:48 PM
  #160
weaver's Avatar
weaver
Thanks for the help
Old Jun 14, 2011 | 07:56 PM
  #161
RedG37SNC's Avatar
RedG37SNC
There is a tendency for the passenger side to sit higher however you can get it to be the same height by keeping the rings at the throttle body loose, adjusting the heat shield to the desired height which should be flush with the hood line and then sinching the rings at the throttle body. The L bracket facing down I believe gives you more play in lowering it. Be careful not to let it get too high or you'll puncture the hood liner.
Old Aug 12, 2011 | 02:23 PM
  #162
IzzyPR's Avatar
IzzyPR
I purchasd my car in march, and I just installed these. The change is to the moon & back. It's more than just sound,HP & Torque numbers. The initial hesitation in acceleration is nearly gone. Responsiveness in every gear is way up. All these are attributed to the short ram design. CAI's tend to give you more up top, but in daily driving who's reving to 7k? Plus the power band in every dyno out there shows this intake being better suited for midrange. I wouldn't change it...unless there's a R2C Version 2.0 to be released.
Old Aug 12, 2011 | 07:40 PM
  #163
Djfarhan's Avatar
Djfarhan
^ amen to r2c 2.0!
Old Aug 15, 2011 | 11:00 AM
  #164
1cleanG's Avatar
1cleanG
NextLevel Performance
This is a true statement...
Old Aug 15, 2011 | 11:15 AM
  #165
VossenG37S's Avatar
VossenG37S
My mid range Pulls hard as F! I been in a IPL w Gen3 and was way quieter and power was not there till higher RPMs but then again how often u in that range ? R2C is still my personall Favorite .
