Windows not automatically rolling down door opens
Old Feb 14, 2024 | 10:41 PM
Ebayfish's Avatar
Ebayfish
Hello all, I have a 2010 G37 convertible. My master window switch recently malfunctioned It was not allowing 2 windows to roll up properly. I replaced the switch and all windows now go up and down with the switch opperation. I did the window reset when you roll the windows all the way down and back up and hold the switch off for an additional 3-5 seconds. The automatic feature works with the switches. Now, since I've done this, when I open the door the window the auto down/up feature no longer rolls down the half inch like a used to. Is there a procedure to fix this?
Old Feb 15, 2024 | 10:42 PM
SkysG37's Avatar
SkysG37
Disconnect the batt for a few minutes, to wipe the window setting memory
when you open the doors they will roll halfway down
close them
Then turn on or start the car, holding the window switches up for 10 sec or so
Hopefully that'll do it for ya
Old Feb 18, 2024 | 01:43 PM
Ebayfish's Avatar
Ebayfish
close them
Thank you. I just tried this and unfortunately there was no change. When I first opened the doors, the windows did not roll down at all. I relearned the window automatic down feature, and unfortunately still no change. I also noticed while playing with it, the driver door window does not drop automatically when the convertible top is put down nor does it operate with the key as It did prior to installing the new master window switch.
Old Feb 19, 2024 | 01:06 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Are you 100% sure the switch is compatible with the 'Vert?
Also, keep in mind the window reset procedure is different for the 'Vert than for the others as the top has to be opened first:
g37noob
Jun 1, 2024 01:28 AM
rosscoupe
Sep 10, 2022 12:41 PM
G37S Bill
May 6, 2014 07:03 PM
onceNaBLUEmoon
General Tech Questions
Dec 12, 2011 10:43 PM
JMM
Sep 11, 2008 04:12 PM
